 Post subject: MRT next software update log
PostPosted: November 3rd, 2017, 16:57
MRT 2110 version, version number: 2.1.1.0
- this software upgrade to charge upgrade
- Added SSD Solid State Drive Repair Module (beta)
Seagate F3 module, upgrade to: 2.0.1.6
- Added LT series, LM series ROM read and write
- Added LT series, LM series family ID is 5F, 87,8C, A5 firmware unlock
- Added NM series family ID is 91 firmware unlock
- Added family ID for 4F Virtual Start
- Added 14 generations of 1CH series of any beheaded
- Added serial load LDR
- Added modified model can support most hard drives
- Added family ID to 72 head adapter
- Added family ID to 4F , 55,59,76,7A, 86,91, A5 read and write ROM support high baud rate
- Added family panel (91,7A, A5)
- Added BootCode read and write ROM support manual modification of configuration files (in MRT installation Directory, file name: SGT-F3GBootCodeBRF.ini)
- optimized family ID for 91 service area track acquisition failure problem
- optimized family ID 56 created LDR incomplete problem
Toshiba module, upgrade to: 2.0.3.7
- increase family HDWJ1 MQ01UBD series
DE module, upgrade to: 2.3.2.2
- new Parse (Apple File System) HFS GPT and DOS partitions + file system based on
the establishment of the compressed bitmap data copy function increases -
- Adds files that are automatically saved in bad files
- Added mount support and file resolution support for larger than 2T capacity disks
- Support for tasks that are larger than 2T mount
- Optimize GPT Partitioning
- Optimize NTFS system resolution
- Added target disk for VHD type support
- DE task file Added version number
- Updated MRTVIRTUAL driver, optimized for greater than 2T capacity Hard drive drive speed
WD Western Digital module, upgrade to 2.2.5.5
- Boot ROM mode New support 1945, 1590, 1552 series hard drive
- the corresponding self-calibration environment initialization function, the automatic correction minority families choose the wrong bug
- new extended self-calibration tool, for users familiar with the use of self-calibration, can be any combination of optional self-calibration process
Samsung Module, upgrade to 2.0.0.2
- add a full range of default module list, optimize the module list to obtain the way, fix the T166 (S) series family of family module list to obtain the problem of failure
- resource download function to increase M7E, M8E and other family support
- resource download , Increase the search for the specified resource function, you can follow the model, firmware version, Part Number (start the process can This data) and other data search, optimization panel
- increased use of serial download Resource Function (Resources panel visible)
- Added write the serial ROM function (write ROM panel visible)
- Added M7E and other family "Start Burn-In test" function And "continue Burn-In test" function
database management tool, upgrade to 1.0.1.7
- Solve the problem of database import failure caused by language encoding in multi-language system.
SSD Solid State Drive Repair Module, Version: 1.0.0.0 (BETA)
- This tool is the initial version
- Contains Samsung SSD Module, Samsung 850, 840, 830 Series SSDs
- Includes Intel 510 Module, Supports Intel 510 Series SSDs
- Includes Marvell Master Module, Supports Series Markers Using Marvell Master, such as Intel 320,710 Series
 Post subject: Re: MRT next software update log
PostPosted: November 5th, 2017, 8:19
Good New for MRT Users :)
PostPosted: November 5th, 2017, 11:48
And where's the link for download?
SSD Module will work on PRO Card??
ACELab partner
PostPosted: November 5th, 2017, 16:42
only chinese version released yet ,this upgrade it's not free and it will cost mrt user 650 yuan,only for users who buy mrt card less then one year is free.
the big problem is sa unlock(sedlock) in wd my passport drive and in this update still not solved.
update log link:http://info.mrtlab.com/download/uplist.htm
PostPosted: November 6th, 2017, 20:06
Why MRT forum has closed creating new posts on all sections except for 'Requests and Feedback' section?
My firmware database:
PostPosted: November 7th, 2017, 1:00
That's what I'm asking too. You cannot post anywhere except that section.
MRT Team do you ever read what we write on forums?
www.datasave.ro
PostPosted: November 7th, 2017, 8:50
Now you can post again on all forum sections, probably they've read my post and fixed the problem :lol:
PostPosted: November 7th, 2017, 9:39
Yes , I see it works.
www.datasave.ro
PostPosted: November 22nd, 2017, 4:57
Hi guys
It looks like MRT has released the new version but not officialy...I mean not a word about it but you can download it from their site
http://us.mrtlab.com/download/MrtEnSetups2112net.rar
http://us.mrtlab.com/download/MrtEnSetups2112.rar
Will see how it works or if it works.
www.datasave.ro
PostPosted: November 22nd, 2017, 8:49
nothing on website yet how you got this :? :?
PostPosted: November 22nd, 2017, 8:50
thanks AnyWay....
PostPosted: November 23rd, 2017, 2:55
Look at their support forum. You'll find there all the news about it.
www.datasave.ro
