Technology mode key : ..........................: OK
RAM: Read HDD Info : ................................: OK Heads number : .................................: 4 Head map : .....................................: 33 SA Cyl Count : .................................: 256 Serials Mark : .................................: 0xFE16 Control version : ..............................: A5C0
Zone allocation table : ........................: Err
ROM: Read Rom Infos : ...............................: OK ROM Data Size : ................................: 512 Kb ROM version : ..................................: 01.55C ROM generation : ...............................: 01.55C Link table version : ...........................: 02.55 ROM Firmware version : .........................: 00010055
ROM Modules: Flash ROM dir reading : ........................: OK Switched off heads : ...........................: Yes Heads number : .................................: 4 Heads number in use : ..........................: 4 heads map : ....................................: 0,1,4,5
SA Module Dir Loading... Load SA Module dir : ...........................: Error, suggest to load from the file Configuration reading : ........................: Err
I need Data , please suggest next steps for recover data
| Attachments: |
