| ST500DM002-KC45 FAIL Servo Op=0100 Resp=0007 http://forum.hddguru.com/viewtopic.php?f=28&t=37114 |
Page 1 of 1 |
| Author: | siamak5561 [ July 18th, 2018, 16:06 ] |
| Post subject: | ST500DM002-KC45 FAIL Servo Op=0100 Resp=0007 |
When switch on i got the following error in terminal and spin down Boot 0x10M Spin Up FAIL Servo Op=0100 Resp=0007 ResponseFrame FFFF 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 FFFF FAIL Servo Op=0100 Resp=0007 ResponseFrame 2EA0 0603 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 FAIL Servo Op=0100 Resp=0007 ResponseFrame 2EA0 0603 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 FAIL Servo Op=0100 Resp=0007 ResponseFrame 2EA0 0603 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 FAIL Servo Op=0100 Resp=0007 ResponseFrame 2EA0 0603 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 FAIL Servo Op=0100 Resp=0007 ResponseFrame 2EA0 0603 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 FAIL Servo Op=0100 Resp=0007 ResponseFrame 2EA0 0603 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 FAIL Servo Op=0100 Resp=0007 ResponseFrame 2EA0 0603 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 FAIL Servo Op=0100 Resp=0007 ResponseFrame 2EA0 0603 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 FAIL Servo Op=0100 Resp=0007 ResponseFrame 2EA0 0603 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 FAIL Servo Op=0100 Resp=0007 ResponseFrame 2EA0 0603 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 I already replaced PCB but nothing changed. |
| Author: | unknown [ July 18th, 2018, 16:09 ] |
| Post subject: | Re: ST500DM002-KC45 FAIL Servo Op=0100 Resp=0007 |
heads are gone |
| Author: | pcimage [ July 19th, 2018, 2:03 ] |
unknown wrote: heads are gone +1 |
| Author: | siamak5561 [ July 19th, 2018, 11:30 ] |
so you sure with head-swap I can recover data? |
| Author: | lcoughey [ July 19th, 2018, 13:30 ] |
siamak5561 wrote: so you sure with head-swap I can recover data? Nobody can be sure...especially about someone else's ability. We do know that you, for sure, that the data won't be recovered without first changing the heads. But, what happens after that depends on your skills and the overall condition of the platters. |
| Author: | siamak5561 [ July 20th, 2018, 13:23 ] |
Thanks guys. |
