| I HAVE ST3500418AS NOT PLIST http://forum.hddguru.com/viewtopic.php?f=28&t=37225 |
Page 1 of 1 |
| Author: | mhp666 [ August 8th, 2018, 14:55 ] |
| Post subject: | I HAVE ST3500418AS NOT PLIST |
I have a disk that could not read the plist. You have these errors when reading the modules. ~0000.rpm : ..........................:OK ~0001.rpm : ..........................:OK ~0002.rpm : ..........................:OK ~0003.rpm : ..........................:Err ~0004.rpm : ..........................:OK ~0005.rpm : ..........................:OK ~0006.rpm : ..........................:Err ~0007.rpm : ..........................:OK ~0008.rpm : ..........................:Err ~0009.rpm : ..........................:OK ~000A.rpm : ..........................:Err ~000B.rpm : ..........................:Err ~000C.rpm : ..........................:Err ~000D.rpm : ..........................:OK ~000E.rpm : ..........................:Err ~000F.rpm : ..........................:OK ~0013.rpm : ..........................:OK ~0015.rpm : ..........................:OK ~0016.rpm : ..........................:OK ~0017.rpm : ..........................:OK ~0019.rpm : ..........................:OK ~001A.rpm : ..........................:OK ~001B.rpm : ..........................:OK ~001C.rpm : ..........................:OK ~001D.rpm : ..........................:OK ~001E.rpm : ..........................:OK ~001F.rpm : ..........................:Err ~002A.rpm : ..........................:OK ~002B.rpm : ..........................:Err ~0033.rpm : ..........................:Err ~0034.rpm : ..........................:Err ~0035.rpm : ..........................:OK ~003A.rpm : ..........................:OK Is there any way to recover the PLIST? |
| Author: | mhp666 [ August 8th, 2018, 17:35 ] |
| Post subject: | Re: I HAVE ST3500418AS NOT PLIST |
I have access to the list of sysfiles, but I can not read any sysfiles. The overlay 05 that module or sysfile is? The full overlay list can someone tell me? |
| Author: | mrtlabinfo [ August 8th, 2018, 21:24 ] |
hi, you can contact our technical support: Email: service@mrtlab.com Skype: live:service_5567 QQ: 2693828612 Have a nice day! |
| Author: | Amarbir[CDR-Labs] [ August 8th, 2018, 23:14 ] |
Hi, This could be a fault of a weak head ,Or might be a actual physical bad sector in drive SA area .I would say try a headswap |
| Author: | mhp666 [ August 9th, 2018, 1:56 ] |
Hello, I have already changed my heads and do exactly the same. What I do not know is if missing the module 03 and also the 2b + 0b, I will be able to recover the data? PCB also changed just in case, although it was evident that it was not PCB problem. |
| Author: | mhp666 [ August 9th, 2018, 11:22 ] |
When I turn on the disk I have access to cp and modules. I do not have access to sysfiles. If I try to read sysfiles, I lose access to cp and modules. |
| Author: | mhp666 [ September 30th, 2018, 14:26 ] |
I keep working on this hard drive with no results. I have found several problems. I'm not sure about everything. Error reading 0x03 and 0x2b, other modules totally written with "0x00", for example 0x01 and 0x02, leave the CAP unacquainted. I have access to the list of SYSFiles, but I do not know where the MRTLAB is from. Although I can not recover the information, I would like to be able to read the sysfiles. Thank you. |
| Author: | mhp666 [ September 30th, 2018, 18:14 ] |
I opened the album after spending a lot of time with him. I did not use a HEPA 100 sale. Still with the same fault since I brought it. In the upper plate I saw a small chopped, and I think that there is the whole problem. I do not read 0x03 nor 0x2b, it always gives me the same reading failure in the SA, from the first day. I have a copy of the SA, but I can not make a copy of the SA tracks, to try to recostruy any of these modules. |
| Author: | mhp666 [ September 30th, 2018, 18:56 ] |
mhp666 wrote: Best advice that i can provide now - do exactly as shown on your avatar picture. I respect you for all your work that you do for others, but I do not share your opinion. I'll keep trying, I get tens of hours dedicated and I'll keep trying. If it were something important to pay for a laboratory and had a solution, it would already be solved. Greetings. |
| Author: | fzabkar [ September 30th, 2018, 21:00 ] |
mhp666 wrote: The overlay 05 that module or sysfile is? The full overlay list can someone tell me? https://forum.acelaboratory.com/viewtopic.php?f=254&t=8612 |
| Author: | mhp666 [ October 1st, 2018, 2:38 ] |
@fzabkar, thank you for the link. |
