 Post subject: I HAVE ST3500418AS NOT PLIST
PostPosted: August 8th, 2018, 14:55
I have a disk that could not read the plist.
You have these errors when reading the modules.
~0000.rpm : ..........................:OK
~0001.rpm : ..........................:OK
~0002.rpm : ..........................:OK
~0003.rpm : ..........................:Err
~0004.rpm : ..........................:OK
~0005.rpm : ..........................:OK
~0006.rpm : ..........................:Err
~0007.rpm : ..........................:OK
~0008.rpm : ..........................:Err
~0009.rpm : ..........................:OK
~000A.rpm : ..........................:Err
~000B.rpm : ..........................:Err
~000C.rpm : ..........................:Err
~000D.rpm : ..........................:OK
~000E.rpm : ..........................:Err
~000F.rpm : ..........................:OK
~0013.rpm : ..........................:OK
~0015.rpm : ..........................:OK
~0016.rpm : ..........................:OK
~0017.rpm : ..........................:OK
~0019.rpm : ..........................:OK
~001A.rpm : ..........................:OK
~001B.rpm : ..........................:OK
~001C.rpm : ..........................:OK
~001D.rpm : ..........................:OK
~001E.rpm : ..........................:OK
~001F.rpm : ..........................:Err
~002A.rpm : ..........................:OK
~002B.rpm : ..........................:Err
~0033.rpm : ..........................:Err
~0034.rpm : ..........................:Err
~0035.rpm : ..........................:OK
~003A.rpm : ..........................:OK
Is there any way to recover the PLIST?
 Post subject: Re: I HAVE ST3500418AS NOT PLIST
PostPosted: August 8th, 2018, 17:35
I have access to the list of sysfiles, but I can not read any sysfiles.
The overlay 05 that module or sysfile is?
The full overlay list can someone tell me?
PostPosted: August 8th, 2018, 21:24
hi, you can contact our technical support:
Email: service@mrtlab.com
Skype: live:service_5567
QQ: 2693828612
Have a nice day!
MRT Lab - Your data recovery, our committed solution.
http://en.mrtlab.com/
PostPosted: August 8th, 2018, 23:14
This could be a fault of a weak head ,Or might be a actual physical bad sector in drive SA area .I would say try a headswap
PostPosted: August 9th, 2018, 1:56
I have already changed my heads and do exactly the same.
What I do not know is if missing the module 03 and also the 2b + 0b, I will be able to recover the data?
PCB also changed just in case, although it was evident that it was not PCB problem.
PostPosted: August 9th, 2018, 11:22
When I turn on the disk I have access to cp and modules.
I do not have access to sysfiles. If I try to read sysfiles, I lose access to cp and modules.
PostPosted: September 30th, 2018, 14:26
I keep working on this hard drive with no results.
I have found several problems. I'm not sure about everything.
Error reading 0x03 and 0x2b, other modules totally written with "0x00", for example 0x01 and 0x02, leave the CAP unacquainted.
I have access to the list of SYSFiles, but I do not know where the MRTLAB is from.
Although I can not recover the information, I would like to be able to read the sysfiles.
Thank you.
PostPosted: September 30th, 2018, 18:14
I opened the album after spending a lot of time with him.
I did not use a HEPA 100 sale.
Still with the same fault since I brought it.
In the upper plate I saw a small chopped, and I think that there is the whole problem.
I do not read 0x03 nor 0x2b, it always gives me the same reading failure in the SA, from the first day. I have a copy of the SA, but I can not make a copy of the SA tracks, to try to recostruy any of these modules.
PostPosted: September 30th, 2018, 18:56
mhp666 wrote:
Best advice that i can provide now - do exactly as shown on your avatar picture.
I respect you for all your work that you do for others, but I do not share your opinion.
I'll keep trying, I get tens of hours dedicated and I'll keep trying.
If it were something important to pay for a laboratory and had a solution, it would already be solved.
Greetings.
PostPosted: September 30th, 2018, 21:00
https://forum.acelaboratory.com/viewtopic.php?f=254&t=8612
PostPosted: October 1st, 2018, 2:38
@fzabkar, thank you for the link.
