firmware needed for maxtor diamondmax plus 9 80 gb pata
Posted: September 28th, 2018, 10:34
Hi guys, I need firmware for pata hdd 80 gb calypso III Maxtor diamondmax plus 9 for MRT, thanks to all
Data recovery and HDD repair discussions
http://forum.hddguru.com/
magnetepazzo wrote:Hi guys, I need firmware for pata hdd 80 gb calypso III Maxtor diamondmax plus 9 for MRT, thanks to all
Spildit wrote:The big question now ...
If this post is the same drive as the other post - viewtopic.php?t=37390 it does look like the OP did already swap heads on the drive so ...
WHY THE HELL didn't he backup the firmware of the donnor drive first ?
If the drive is compatible enough for the heads to work on the damaged drive i would say that the first thing to do would be to backup the working drive firmware for later use ?
