 Post subject: ST500LT012 TERMINAL FAIL
PostPosted: September 27th, 2018, 12:45
Failed to recognize in bootcode.
It shows wrong characters. In normal f3 normal mode it detects it well.
2 clicks and the mortor stops.
It is a case study, no matter the data.
 Post subject: Re: ST500LT012 TERMINAL FAIL
PostPosted: September 30th, 2018, 17:50
It is a broken unit.
It does 2 clicks and it stops in 1 second ~.
If I do not connect it to the mrtlab, it does not detect it and the engine stops immediately.
Once I stopped the engine if I detected it with mrtlab I detected it as SEAGATE and then as generic.
I'm going to select it as a thin laptop and it has short-circuited the ROM and if I read it I upload it.
Thank you.
PostPosted: October 2nd, 2018, 9:57
When I get another one like this, I will study it carefully, and I will put the results we find.
Thanks for your interest.
PostPosted: October 2nd, 2018, 14:36
By isolating the PCB and selecting the Yarax family 86 HDD model instead of the one detected by the MRTLAB (Yarrar_5400), the terminal works correctly.
It gives me the wrong head type failure, but it is normal the PCB is isolated.
I assume they are the heads that are wrong. I have visualized CAP, SAP and RAP and they seem to be correct.
