 Post subject: ST500DM002 Error
PostPosted: January 6th, 2019, 9:47
Online
HDD: ST500DM002-1BD142 With KC45 Firmware
I m getting this error
Starting LBA of RW Request=0013209D Length=00000148
ProcessRWError -Read- at LBA 0013209D Sense Code=C3160080
FAIL Servo Op=008F Resp=0003
ResponseFrame 0D3E 0400 0003 8E4F 0002 EE30 FB80 0000 129A 0000 0000 0000 0000 0000 0000 0000 0000
RECOV Servo Op=0165 Resp=0005
RTL exceeded
Starting LBA of RW Request=001320A1 Length=00000144
ProcessRWError -Read- at LBA 001320A1 Sense Code=43110081
ResponseFrame 0015 0001 0000 0000 0002 EE30 FB80 0000 129A 0000 0000 0000 0000 0000 0000 0000 C100
ResponseFrame 0001 0000 0000 0265 0002 EE30 FB80 0000 129A 0000 0000 0000 0000 0000 0000 0000 FFFF
RTL exceeded
Starting LBA of RW Request=001320A5 Length=00000140
ProcessRWError -Read- at LBA 001320A5 Sense Code=C3160080
RTL exceeded
Starting LBA of RW Request=001320A9 Length=0000013C
ProcessRWError -Read- at LBA 001320A9 Sense Code=C3160080
qV{00000008}qV{00000008}qV{00000008}qV{00000008}qV{00000008}qV{00000008}qV{00000008}qV{00000008}qV{00000008}
Endless and No F3 T> prompt
How to Solve this issue..
 Post subject: Re: ST500DM002 Error
PostPosted: January 7th, 2019, 1:50
Use Virtual Boot to stop the pending issue. After that work with firmware or start copying data if everything is ok in firmware.
www.datasave.ro
PostPosted: January 7th, 2019, 2:25
Online
When tried with virtualBoot
i m getting
Patch_BUST_ProcessRWErrorWrite failed!
PostPosted: January 7th, 2019, 2:26
Banned User
i m getting
this is not the end , you can still continue the process, I can help you try fixing if you want , but not free
