| Using the COM Port UART Adapter http://forum.hddguru.com/viewtopic.php?f=28&t=38354 |
Page 1 of 1 |
| Author: | alfarom [ April 29th, 2019, 15:35 ] |
| Post subject: | Using the COM Port UART Adapter |
I know this should be straightforward but I can seem to connect to the COM port on any of the hard drives I've got using the UART USB card. Is there a vido anywhere that shows not only how to connect it but what lights should be on the card and how it looks in program itself? |
| Author: | alfarom [ April 30th, 2019, 8:43 ] |
| Post subject: | Re: Using the COM Port UART Adapter |
Seems like it only happens with WD drives. I'll have to try a different connector. |
| Author: | HaQue [ April 30th, 2019, 11:03 ] |
edited due to being probably wrong... |
| Author: | alfarom [ April 30th, 2019, 20:26 ] |
What do you mean? |
| Author: | fzabkar [ April 30th, 2019, 20:40 ] |
@alfarom, when you say "the UART USB card", what do you mean by "the"? The early card was limited to 3.3V I/O whereas the latest card can handle 2.5V and 1.8V. |
| Author: | alfarom [ May 1st, 2019, 14:44 ] |
The later card. Doesn't matter now it seems that I was only getting a problem with a couple of WD drives. |
