 Post subject: ST3000DM001
PostPosted: August 17th, 2019, 17:35
Anything to do here? It spins up, click twice and spins down It gets ID, firmware etc, but says the size is 3,86gb. Is this dead or is there something i can do?
 Post subject: Re: ST3000DM001
PostPosted: August 17th, 2019, 18:06
Hi.
I think it is a lost case.
Every time the needles pass through that area I think they will break.
Also if I'm not mistaken, the other surfaces of the HDD have the same scratch.
A greeting.
PostPosted: August 18th, 2019, 5:29
most likely gone, if customer is willing, partial recovery can be attempted...
Data Recovery Pakistan
PostPosted: August 18th, 2019, 8:00
Yes, maybe possible for partial but requires thorough investigation...
Not cheap :-(
PostPosted: August 18th, 2019, 12:54
Ok, do you know how to partially recover? I have both mrt and pc3k available.
PostPosted: August 18th, 2019, 12:59
In your case I would remove top head, do the necessary ROM modifications to get the drive to start without h5
Digitalsupport Data Recovery
https://digitalsupport.dk
PostPosted: August 18th, 2019, 13:01
After checking all heads for debris under the microscope of course! :-)
But in any case, it’s a cleanroom job.
PostPosted: August 19th, 2019, 0:01
I take so many things for granted, thank you for completing my answer pcimage :)
