 Post subject: SAMSUNG HM250HI/SCC (PN 3462) LED110C ERROR
PostPosted: August 28th, 2019, 12:30
HI!
I changed the headstack of this drive two times (two donors).
-- The first try (head swap) i can read almost 80GB with both heads and later with the head 1 only and then, LED110C.
-- The second try (head swap), the LED110C error showed on terminal and i cant read nothing.
I returned the heads to the DONORS and both now are showing LED110C (same log):
*PA VID=0007 PN=0000 Rev=0004*PA VID=0007 PN=0000 Rev=0004PSL U
S_0Shock Sensor Circuit Enabled
SO_1
Init RPM=0
IS=4
CLA #36/58
Handoff RPM=655
SPOK
mS1 00000003
A1O=116 A1G=434
O=513 S=1
***** No Gray
SoUL!
PK_3 C: 0 H:0
A1O=116 A1G=435
O=513 S=1
***** No Gray
SoUL!
PK_3 C: 0 H:1
A1O=116 A1G=435
O=513 S=2
***** No Gray
SoUL!
PK_3 C: 0 H:0
A1O=116 A1G=436
O=513 S=1
***** No Gray
SoUL!
PK_3 C: 0 H:1
A1O=116 A1G=436
O=513 S=2
***** No Gray
SoUL!
PK_3 C: 0 H:0
A1O=116 A1G=437
O=513 S=0
***** No Gray
SoUL!
PK_3 C: 0 H:1
A1O=116 A1G=437
O=513 S=1
***** No Gray
SoUL!
PK_3 C: 0 H:0
A1O=116 A1G=437
O=513 S=2
***** No Gray
SoUL!
PK_3 C: 0 H:1
A1O=116 A1G=437
O=514 S=3
***** No Gray
SoUL!
PK_3 C: 0 H:0
A1O=116 A1G=438
O=513 S=0
***** No Gray
SoUL!
PK_3 C: 0 H:1
A1O=116 A1G=438
O=513 S=1
***** No Gray
SoUL!
PK_3 C: 0 H:0
A1O=116 A1G=438
O=513 S=2
***** No Gray
SoUL!
PK_3 C: 0 H:1
A1O=116 A1G=439
O=513 S=0
***** No Gray
SoUL!
PK_3 C: 0 H:0
A1O=116 A1G=439
O=513 S=0
***** No Gray
SoUL!
PK_3 C: 0 H:1
A1O=116 A1G=438
O=513 S=3
***** No Gray
SoUL!
PK_3 C: 0 H:0
A1O=116 A1G=439
O=513 S=1
***** No Gray
SoUL!
PK_3 C: 0 H:1
Unlatch Fail
Software unloading!
PK_4 C: 0 H:0
Software unloading!
PK_4 C: 0 H:0
LED 110C
LED 110C
LED 110C
LED 110C
LED 110C
LED 110C
LED 110C
LED 110C
LED 110C
LED 110C
LED 110C
LED 110C
LED 110C
File comment: DONOR
File comment: DONOR 2
File comment: PATIENT
 Post subject: Re: SAMSUNG HM250HI/SCC (PN 3462) LED110C ERROR
PostPosted: August 28th, 2019, 17:12
Most likely drive have media damage that killing heads,hope you did backup firmware before imaging.
And this case is for experts who have experience in such situation.
PostPosted: August 31st, 2019, 8:32
Thanks. I have the resources backup of this drive. Im curious because I can´t find the LED110C error description in any place. I hope somebody here have saw this LED110C error before.
PostPosted: September 1st, 2019, 15:19
I have this listing in Spanish. Hope this can help you.
Códigos de error de Samsung.rar [13.75 KiB]
Downloaded 853 times
PostPosted: September 3rd, 2019, 5:39
LED error occurre when ,
Wrong Rom or
Bad sector on SA or
Weak head or
Bad head
Sexy Womans from your town
PostPosted: September 3rd, 2019, 11:23
Thanks for the list, very good! Unfortunately the 110C isn't listed.
Master Mind Support - Data Recovery
PostPosted: September 3rd, 2019, 12:25
Wrong Rom or
Bad sector on SA or
Weak head or
Bad head
I will try another head swap.
