Seagate ST4000nm053 "DiagError 00000001" issue
http://forum.hddguru.com/viewtopic.php?f=28&t=40448
Author:  cgm [ September 30th, 2020, 14:53 ]
Post subject:  Seagate ST4000nm053 "DiagError 00000001" issue
I'm having some issues with this drive (ST4000nm053) *Megalodon. I'm able read rom and unlock, but I get this error "DiagError 00000001" after executing commands. The only one that works is clear smart. I just want repair the drive, no data recovery. No clicking noises or knocking noises, runs fine. Any input is appreciated.
Thanks,
CG
Author:  ccc [ October 2nd, 2020, 9:07 ]
Post subject:  Re: Seagate ST4000nm053 "DiagError 00000001" issue
Hi
As you can see , the utility can't find modules or DT or sys files when entering....It is still locked I suppose....Or the unlock procedure was not finished correctly....or MRT can not unlock this drives yet...
In this state you can't do anything in terminal....It needs to be unlocked first.
Rgds
Author:  pepe [ October 3rd, 2020, 20:10 ]
This one requires another type of unlock... Very simple though.
Author:  cgm [ October 5th, 2020, 10:50 ]
Using MRT or another software? I also have PC-3000 but same issue there.
Thanks,
CG
Author:  Popica [ January 30th, 2022, 5:02 ]
So what is the solution here?
