Head 0 - OK Head 1 - OK Head 2 - Ok Head 3 - OK
While making Image made image with Head 1,2,3 Next made with Head 0 - error reading many sectors. (see the Attach screen)
Any Help or suggestion "FAILED TO READ" Sector's LOG: Technology mode key : ..........................: OK
RAM: Read HDD Info : ................................: OK Heads number : .................................: 4 Head map : .....................................: F SA Cyl Count : .................................: 256 Serials Mark : .................................: 0xD316 Control version : ..............................: 63B0
Zone allocation table : ........................: OK SA SPT : .......................................: 899
ROM: Read Rom Infos : ...............................: OK ROM Data Size : ................................: 256 Kb ROM version : ..................................: 14.DHQ ROM generation : ...............................: 14.DHQ Link table version : ...........................: 05.CP ROM Firmware version : .........................: 001400DH
ROM Modules: Flash ROM dir reading : ........................: OK Switched off heads : ...........................: Yes Heads number : .................................: 0x4 Heads number in use : ..........................: 0x4 heads map : ....................................: 0,1,2,3
Load SA translator : ...........................: OK
SA Module Dir Loading... Load SA Module dir : ...........................: OK Configuration reading : ........................: OK Master Password : ..............................: has not been set User Password : ................................: has not been set
BTW : Translator Generation done : successfully.
Thanks in Advance for help/suggestion.
| Attachments: |
