 Post subject: WD40NMZW-11GX6S1 failed to ID
PostPosted: June 1st, 2020, 4:17
Hi need some help here.
I have this patient drive WD40NMZW-11GX6S1 which I swaped the USB PCB to SATA. After that I tried to load them into MRT utility by shortening TV9 and TV10. I couldn't manage to ID it. It failed and stuck in busy mode. Did I missed anything or is there another way to get this drive to ID in MRT?
Patient USB PCB: 2060-800041-003- Rev P1
SATA PCB: 2060-800022-002 Rev P1
 Post subject: Re: WD40NMZW-11GX6S1 failed to ID
PostPosted: November 8th, 2020, 23:18
Hi. Did you find a solution? I have the exact same case
PostPosted: November 21st, 2020, 1:00
is this unlocked pcb ?
with out unlock pcb you can't access SA.
PostPosted: November 21st, 2020, 3:26
I don't think this is true. It's Spyglass I.
What is original problem of the drive?
Why you want to short read channel?
PostPosted: November 21st, 2020, 9:27
sata pcb should work like charm as *northwind* mentioned to.
what the customer told you ?!
Btw it's sed lock drive did you try to block access to sa and make diagnoses ?!
PostPosted: November 21st, 2020, 13:01
Not true.
PostPosted: November 25th, 2020, 16:18
Not true.
Could you explain the unlocked pcb bypass?
PostPosted: November 25th, 2020, 16:27
Not true.
No such thing as “unlocked PCB” for Spyglass, it’s just a SATA one from a SATA version. I think mainly they come from WD wireless drives.
PostPosted: November 25th, 2020, 17:11
Not true.
Ahhh, my bad. Somehow my brain convinced me this was a Charger.
Guess I'll have to buy 800065. Do you recomend a seller in particular?
PostPosted: November 26th, 2020, 4:16
Donordrives, hddzone... or freelancers like eric lee or sunny. Be careful if you buy from alibaba etc, you can find good prices but you have no guarantee what you'll get. I got two of these Spyglass SATA PCBs and they both arrived dead. I managed to fix one of them but the other was FUBAR.
Donordrives and hddzone will give you moneyback or replacement guarantee in case something goes wrong with the part.
PostPosted: December 6th, 2020, 18:01
regarding the whole locking and unlocking mechanism.
Has that got something to do with the bootloader of the MCU.
Example: STM32 Nucleo boards are supplied with factory bootloader that resides in some offset in the MCU itself considering June 2018RM0385 Rev 81/17241RM0385Reference manual.
It would be quite a job to know the MCU chip id, find its memory map and investigate the BL.
Also, do you think the unlocked boards are just having a BL patched to bypass security features.
As a novice embedded guy,I am just guessing.
let me know.
