| Toshiba MQ01ABD http://forum.hddguru.com/viewtopic.php?f=28&t=41117 |
Page 1 of 1 |
| Author: | Josh256 [ March 23rd, 2021, 5:30 ] |
| Post subject: | Toshiba MQ01ABD |
hi i have a Toshiba MQ01ABD that suddenly stopped detecting to windows. it spins no clicking sound and connect to MRT shows HDD information: serial and model...etc. Selected family:MQ01ABD Model:TOSHIBA MQ01ABD100H Load Zones : .........................:OK Cyl Num : ............................:232110 Head Num : ...........................:4 Vendor : .............................:TOSHIBA Model : ..............................:MQ01ABD100H Microcode : ..........................:ALF07M0F Defects in G-List : ..................1225 CP list:33,34,44,56,92,95,98,9A,9C,A2,A5,A7,A8,A9,AA,AD,AE,B1,B3,BB,BF,C1,C5,C6,C7,C8,C9,CB,CD,D0,D1,D3,D4,D6,D7,D9,DA,DB,DC,DD,EF,F1,F3,F4,F7,F8,FA,FB,FC,FF i tried to clear SMART and Glist but still in Data Explorer it fails and cannot open the files or read the data and these errors appears: 19:25:15 Read Failed SourceLBA = 0 DestnLBA = 0 19:25:15 Read Failed SourceLBA = 0 DestnLBA = 0 19:25:15 Parse node failed! Node path = MRT ATA0 - TOSHIBA MQ01ABD100H - 931.51 GB 19:25:15 Read Failed SourceLBA = 0 DestnLBA = 0 also when i go to copy data and it starts reading he sectors all the sectors are red. when i try to Backup Rom i get this error: Saving ROM...... Save to the target file:C:\UserDataFile\Toshiba\MQ01ABD\TOSHIBA MQ01ABD100H-ALF07M0F-13P6C7WLT\Data\ROM\0-7FFFF.bin Address : ............................:0x0 Length : .............................:0x80000 Error in reading ROM! any help would be appreciated |
| Author: | labtech [ March 23rd, 2021, 5:52 ] |
| Post subject: | Re: Toshiba MQ01ABD |
It is a hybrid drive. Probably problem is with NAND component. |
| Author: | Josh256 [ March 23rd, 2021, 7:38 ] |
labtech wrote: It is a hybrid drive. Probably problem is with NAND component. Thank you for your reply, is there anyway to confirm? if the NAND is defective and i replace the motherboard and swap the ROM chip would it fix the problem? |
| Author: | MasterT [ March 23rd, 2021, 10:47 ] |
Toshiba SSHD (Hybrid drives) You have to issue >NVA command in terminal and Restart Drive. This will disable NAND on the drive. After that check if you can read the drive. |
| Author: | thakurasr [ March 23rd, 2021, 14:09 ] |
pls pay attention on Techno off and then reidetify hdd. and check sechora are readable? |
| Author: | Josh256 [ March 23rd, 2021, 20:46 ] |
thakurasr wrote: pls pay attention on Techno off and then reidetify hdd. and check sechora are readable? thank you for your reply. tried Techno off but unfortunately it didn't work |
| Author: | Josh256 [ March 23rd, 2021, 20:52 ] |
MasterT wrote: Toshiba SSHD (Hybrid drives) You have to issue >NVA command in terminal and Restart Drive. This will disable NAND on the drive. After that check if you can read the drive. Thank you, i don't know how to send commands. i read on data_medics and hddoracle to press entre and it will show > prompt. i connected the terminal port (by USB) but i don't know where to press entre? should i press entre when i get into Toshiba utility? |
| Author: | ccc [ March 24th, 2021, 2:12 ] |
No. The Toshiba utility doesn't have a Terminal tab....You'll have to use another utility which have terminal tab (Seagate for ex.) and correct baud rate set or a separate software in windows. Rgds |
| Author: | Josh256 [ March 24th, 2021, 21:08 ] |
ccc wrote: No. The Toshiba utility doesn't have a Terminal tab....You'll have to use another utility which have terminal tab (Seagate for ex.) and correct baud rate set or a separate software in windows. Rgds Thank you, i followed your instructions and it fixed the problem so i imaged the whole drive to another also i tried to connect the faulty Toshiba hdd directly to windows to see if i would work now and it did work and all the files and data are accessible. thanks everyone for helping me out |
| Author: | kor.srg [ June 9th, 2022, 6:25 ] |
Josh256 wrote: ccc wrote: No. The Toshiba utility doesn't have a Terminal tab....You'll have to use another utility which have terminal tab (Seagate for ex.) and correct baud rate set or a separate software in windows. Rgds Thank you, i followed your instructions and it fixed the problem so i imaged the whole drive to another also i tried to connect the faulty Toshiba hdd directly to windows to see if i would work now and it did work and all the files and data are accessible. thanks everyone for helping me out I have the same problem with Toshiba MQ01ABD. Please tell, what tool did you use. I can't find a terminal tab in SeaTools for DOS 1.12 |
| Author: | labtech [ June 11th, 2022, 5:31 ] |
Is your drive a hybrid model, too? If it is not, then the problem is different. |
| Author: | kor.srg [ June 11th, 2022, 7:50 ] |
labtech wrote: Is your drive a hybrid model, too? If it is not, then the problem is different. Yes, I have a hybrid model. I've bougth a usb->com convertor and connected to the HDD with putty terminal. NVA command solved my problem. Thanks everyone for the tips |
