 Post subject: WD500LMVW-11VEDS0 , Zone Allocation table Error
PostPosted: April 9th, 2021, 3:42
WD500LMVW-11VEDS0 , Zone Allocation table Error , I try to repair module 11 as existing module was Error. But mod 11 write to HDD also error. Possible head NG ? I trt to replaced the head with good donor, problem remain. As on WorkLog file so many modules Error. need your help. thanks.
File comment: Zone allocation table Err
 Post subject: Re: WD500LMVW-11VEDS0 , Zone Allocation table Error
PostPosted: April 10th, 2021, 1:27
Here is working log :
WD5000LMVW-11VEDS0-01-01A01-WD-WXB1A63f4131
Technology mode key : ..........................: OK
RAM:
Read HDD Info : ................................: OK
Heads number : .................................: 2
Head map : .....................................: 3
SA Cyl Count : .................................: 256
Serials Mark : .................................: 0xFE16
Control version : ..............................: A5C0
Zone allocation table : ........................: Err
ROM:
Read Rom Infos : ...............................: OK
ROM Data Size : ................................: 256 Kb
ROM version : ..................................: 06.1TK
ROM generation : ...............................: 06.1TK
Link table version : ...........................: NE.11
ROM Firmware version : .........................: 0006001T
ROM Modules:
Flash ROM dir reading : ........................: OK
Switched off heads : ...........................: Yes
Heads number : .................................: 0x2
Heads number in use : ..........................: 0x2
heads map : ....................................: 0,1
Load SA translator : ...........................: OK
SA Module Dir Loading...
Load SA Module dir : ...........................: OK
Configuration reading : ........................: OK
Master Password : ..............................: has not been set
User Password : ................................: has not been set
Saving ROM
Save Path:C:\UserDataFile\WDC Marvell\Hubble LT\20210410-113105-0006001T\Data\ROM\ROM_.bin
Save ROM: : ....................................: OK
Saving ROM module
Save the module: 0A : ..........................: OK
Save the module: 0B : ..........................: OK
Save the module: 20B : .........................: OK
Save the module: 30 : ..........................: OK
Save the module: 47 : ..........................: OK
Save the module: 0D : ..........................: OK
Save the module: 4F : ..........................: OK
Backup of ROM module completed!
Saving Module
Save the module:0001 ByID : ....................: OK
Save the module:0002 ByID : ....................: OK
Save the module:0003 ByID : ....................: OK
Save the module:0004 ByID : ....................: ERR(Read Fail)
Save the module:000C ByID : ....................: OK
Save the module:0011 ByID : ....................: ERR(Read Fail)
Save the module:001B ByID : ....................: OK
Save the module:0021 ByID : ....................: ERR(Read Fail)
Save the module:0023 ByID : ....................: OK
Save the module:0024 ByID : ....................: OK
Save the module:0025 ByID : ....................: OK
Save the module:0026 ByID : ....................: OK
Save the module:0028 ByID : ....................: OK
Save the module:0029 ByID : ....................: OK
Save the module:002A ByID : ....................: OK
Save the module:002D ByID : ....................: ERR(Read Fail)
Save the module:002E ByID : ....................: OK
Save the module:002F ByID : ....................: OK
Save the module:0031 ByID : ....................: ERR(Read Fail)
Save the module:0032 ByID : ....................: OK
Save the module:0033 ByID : ....................: ERR(Read Fail)
Save the module:0034 ByID : ....................: OK
Save the module:0035 ByID : ....................: OK
Save the module:0036 ByID : ....................: OK
Save the module:0037 ByID : ....................: OK
Save the module:0038 ByID : ....................: OK
Save the module:0039 ByID : ....................: OK
Save the module:003A ByID : ....................: OK
Save the module:003B ByID : ....................: OK
Save the module:003C ByID : ....................: OK
Save the module:003D ByID : ....................: OK
Save the module:003E ByID : ....................: OK
Save the module:003F ByID : ....................: OK
Save the module:0040 ByID : ....................: OK
Save the module:0041 ByID : ....................: ERR(Read Fail)
Save the module:0042 ByID : ....................: OK
Save the module:0043 ByID : ....................: OK
Save the module:0049 ByID : ....................: OK
Save the module:004A ByID : ....................: OK
Save the module:004D ByID : ....................: OK
Save the module:004E ByID : ....................: ERR(Read Fail)
Save the module:0050 ByID : ....................: OK
Save the module:0051 ByID : ....................: OK
Save the module:0052 ByID : ....................: OK
Save the module:0053 ByID : ....................: OK
Save the module:0062 ByID : ....................: OK
Save the module:0063 ByID : ....................: OK
Save the module:0066 ByID : ....................: OK
Save the module:0068 ByID : ....................: OK
Save the module:0069 ByID : ....................: OK
Save the module:006A ByID : ....................: OK
Save the module:006B ByID : ....................: OK
Save the module:006D ByID : ....................: OK
Save the module:006E ByID : ....................: OK
Save the module:006F ByID : ....................: ERR(Read Fail)
Save the module:0081 ByID : ....................: OK
Save the module:009A ByID : ....................: OK
Save the module:00B1 ByID : ....................: OK
Save the module:00B2 ByID : ....................: OK
Save the module:00B5 ByID : ....................: ERR(Read Fail)
Save the module:00B6 ByID : ....................: OK
Save the module:00B7 ByID : ....................: OK
Save the module:00B8 ByID : ....................: OK
Save the module:00B9 ByID : ....................: OK
Save the module:00BA ByID : ....................: OK
Save the module:00BB ByID : ....................: OK
Save the module:00BC ByID : ....................: ERR(Read Fail)
Save the module:00BD ByID : ....................: OK
Save the module:00BE ByID : ....................: OK
Save the module:00BF ByID : ....................: OK
Save the module:00C5 ByID : ....................: ERR(Read Fail)
Save the module:00D0 ByID : ....................: OK
Save the module:00D1 ByID : ....................: OK
Save the module:00D3 ByID : ....................: OK
Save the module:00D4 ByID : ....................: OK
Save the module:00D5 ByID : ....................: ERR(Read Fail)
Save the module:00D7 ByID : ....................: OK
Save the module:00D8 ByID : ....................: OK
Save the module:00D9 ByID : ....................: ERR(Read Fail)
Save the module:00DB ByID : ....................: OK
Save the module:00DC ByID : ....................: OK
Save the module:00DD ByID : ....................: OK
Save the module:00DE ByID : ....................: OK
Save the module:00DF ByID : ....................: ERR(Read Fail)
Save the module:00E0 ByID : ....................: ERR(Read Fail)
Save the module:00E1 ByID : ....................: ERR(Read Fail)
Save the module:00E6 ByID : ....................: OK
Save the module:00E7 ByID : ....................: OK
Save the module:00E8 ByID : ....................: OK
Save the module:00E9 ByID : ....................: ERR(Read Fail)
Save the module:00EE ByID : ....................: OK
Save the module:00F7 ByID : ....................: OK
Save the module:00FA ByID : ....................: OK
Save the module:00FC ByID : ....................: OK
Save the module:00FD ByID : ....................: OK
Save the module:00FE ByID : ....................: ERR(Read Fail)
Save the module:0102 ByID : ....................: OK
Save the module:0103 ByID : ....................: OK
Save the module:0104 ByID : ....................: OK
Save the module:0105 ByID : ....................: OK
Save the module:0106 ByID : ....................: OK
Save the module:0108 ByID : ....................: OK
Save the module:0109 ByID : ....................: OK
Save the module:0115 ByID : ....................: OK
Save the module:0116 ByID : ....................: OK
Save the module:0118 ByID : ....................: OK
Save the module:0119 ByID : ....................: OK
Save the module:0120 ByID : ....................: OK
Save the module:0121 ByID : ....................: ERR(Read Fail)
Save the module:0122 ByID : ....................: OK
Save the module:0123 ByID : ....................: OK
Save the module:0124 ByID : ....................: OK
Save the module:0125 ByID : ....................: OK
Save the module:0126 ByID : ....................: OK
Save the module:0127 ByID : ....................: OK
Save the module:0128 ByID : ....................: OK
Save the module:012A ByID : ....................: OK
Save the module:012B ByID : ....................: OK
Save the module:012D ByID : ....................: ERR(Read Fail)
Save the module:012E ByID : ....................: OK
Save the module:0131 ByID : ....................: OK
Save the module:0132 ByID : ....................: OK
Save the module:0149 ByID : ....................: OK
Save the module:014A ByID : ....................: OK
Save the module:016F ByID : ....................: OK
Save the module:0191 ByID : ....................: OK
Save the module:022D ByID : ....................: OK
Save the module:0411 ByID : ....................: OK
Save the module:0600 ByID : ....................: OK
Save the module:0601 ByID : ....................: OK
Save the module:1000 ByID : ....................: OK
Save the module:1001 ByID : ....................: OK
Save the module:1002 ByID : ....................: OK
Save the module:1003 ByID : ....................: OK
Save the module:1004 ByID : ....................: OK
Save the module:1005 ByID : ....................: OK
Save the module:1007 ByID : ....................: OK
Save the module:1008 ByID : ....................: OK
Save the module:1009 ByID : ....................: OK
Save the module:100A ByID : ....................: OK
Save the module:100B ByID : ....................: OK
Save the module:100C ByID : ....................: OK
Save the module:100E ByID : ....................: OK
Save the module:100F ByID : ....................: OK
Save the module:1010 ByID : ....................: OK
Save the module:1011 ByID : ....................: OK
Save the module:1100 ByID : ....................: OK
Save the module:1101 ByID : ....................: OK
Save the module:1102 ByID : ....................: OK
Save the module:1104 ByID : ....................: OK
Save the module:1121 ByID : ....................: ERR(Read Fail)
Save the module:120F ByID : ....................: OK
Save the module:1213 ByID : ....................: OK
Save the module:13F1 ByID : ....................: OK
Save the module:13F2 ByID : ....................: OK
Save the module:13F5 ByID : ....................: OK
Save the module:1400 ByID : ....................: OK
Save the module:1410 ByID : ....................: OK
Save the module:1430 ByID : ....................: OK
Save the module:1800 ByID : ....................: OK
Save the module:1801 ByID : ....................: OK
Save the module:1802 ByID : ....................: OK
Save the module:1803 ByID : ....................: OK
Save the module:1804 ByID : ....................: OK
Save the module:1901 ByID : ....................: OK
Save the module:1902 ByID : ....................: OK
Save the module:1903 ByID : ....................: OK
Save the module:2401 ByID : ....................: OK
Save the module:2403 ByID : ....................: OK
Save the module:2404 ByID : ....................: ERR(Read Fail)
Save the module:2407 ByID : ....................: OK
Save the module:2408 ByID : ....................: ERR(Read Fail)
Save the module:2409 ByID : ....................: OK
Save the module:240A ByID : ....................: ERR(Read Fail)
Save the module:240B ByID : ....................: OK
Save the module:240C ByID : ....................: OK
Save the module:240E ByID : ....................: OK
Save the module:2410 ByID : ....................: OK
Save the module:2413 ByID : ....................: OK
Save the module:2414 ByID : ....................: OK
Save the module:2415 ByID : ....................: OK
Save the module:241A ByID : ....................: OK
Save the module:241D ByID : ....................: OK
Save the module:241E ByID : ....................: OK
Save the module:241F ByID : ....................: ERR(Read Fail)
Save the module:2420 ByID : ....................: OK
Save the module:2422 ByID : ....................: OK
Save the module:2423 ByID : ....................: OK
Save the module:2424 ByID : ....................: OK
Save the module:2427 ByID : ....................: ERR(Read Fail)
Save the module:2429 ByID : ....................: OK
Save the module:242C ByID : ....................: OK
Save the module:242D ByID : ....................: OK
Save the module:2503 ByID : ....................: OK
Save the module:2504 ByID : ....................: OK
Save the module:2507 ByID : ....................: OK
Save the module:2508 ByID : ....................: OK
Save the module:2509 ByID : ....................: OK
Save the module:250B ByID : ....................: OK
Save the module:250C ByID : ....................: ERR(Read Fail)
Save the module:250E ByID : ....................: OK
Save the module:2513 ByID : ....................: OK
Save the module:2514 ByID : ....................: ERR(Read Fail)
Save the module:2515 ByID : ....................: OK
Save the module:251D ByID : ....................: OK
Save the module:251E ByID : ....................: OK
Save the module:251F ByID : ....................: ERR(Read Fail)
Save the module:2520 ByID : ....................: ERR(Read Fail)
Save the module:2522 ByID : ....................: OK
Save the module:2527 ByID : ....................: OK
Save the module:2529 ByID : ....................: OK
Save the module:2640 ByID : ....................: OK
Save the module:2641 ByID : ....................: OK
Save the module:2670 ByID : ....................: ERR(Read Fail)
Save the module:2671 ByID : ....................: OK
Save the module:2680 ByID : ....................: OK
Save the module:2681 ByID : ....................: OK
Save the module:2690 ByID : ....................: OK
Save the module:2691 ByID : ....................: OK
Save the module:26D0 ByID : ....................: ERR(Read Fail)
Save the module:26D1 ByID : ....................: OK
Save the module:26E0 ByID : ....................: OK
Save the module:26E1 ByID : ....................: OK
Save the module:2804 ByID : ....................: OK
Save the module:290A ByID : ....................: OK
Save the module:2D03 ByID : ....................: ERR(Read Fail)
Save the module:2D04 ByID : ....................: ERR(Read Fail)
Save the module:2D07 ByID : ....................: ERR(Read Fail)
Save the module:2D08 ByID : ....................: ERR(Read Fail)
Save the module:2D09 ByID : ....................: ERR(Read Fail)
Save the module:2D0B ByID : ....................: ERR(Read Fail)
Save the module:2D0C ByID : ....................: ERR(Read Fail)
Save the module:2D0E ByID : ....................: ERR(Read Fail)
Save the module:2D13 ByID : ....................: ERR(Read Fail)
Save the module:2D14 ByID : ....................: ERR(Read Fail)
Save the module:2D15 ByID : ....................: ERR(Read Fail)
Save the module:2D1D ByID : ....................: ERR(Read Fail)
Save the module:2D1E ByID : ....................: ERR(Read Fail)
Save the module:2D1F ByID : ....................: ERR(Read Fail)
Save the module:2D20 ByID : ....................: ERR(Read Fail)
Save the module:2D22 ByID : ....................: ERR(Read Fail)
Save the module:2D27 ByID : ....................: ERR(Read Fail)
Save the module:2D29 ByID : ....................: ERR(Read Fail)
Save the module:2E00 ByID : ....................: OK
Save the module:2F01 ByID : ....................: OK
Save the module:2F02 ByID : ....................: OK
Save the module:2F03 ByID : ....................: OK
Save the module:2F04 ByID : ....................: OK
Save the module:2F08 ByID : ....................: OK
Save the module:2FF0 ByID : ....................: ERR(Read Fail)
Save the module:3300 ByID : ....................: OK
Save the module:3301 ByID : ....................: OK
Save the module:3302 ByID : ....................: ERR(Read Fail)
Save the module:3303 ByID : ....................: OK
Save the module:3304 ByID : ....................: OK
Save the module:3305 ByID : ....................: OK
Save the module:3307 ByID : ....................: OK
Save the module:3309 ByID : ....................: OK
Save the module:3310 ByID : ....................: OK
Save the module:3311 ByID : ....................: OK
Save the module:3312 ByID : ....................: OK
Save the module:3400 ByID : ....................: OK
Save the module:3401 ByID : ....................: OK
Save the module:3402 ByID : ....................: ERR(Read Fail)
Save the module:3405 ByID : ....................: OK
Save the module:3406 ByID : ....................: OK
Save the module:3407 ByID : ....................: OK
Save the module:3408 ByID : ....................: OK
Save the module:3411 ByID : ....................: OK
Save the module:3413 ByID : ....................: OK
Save the module:3414 ByID : ....................: OK
Save the module:3416 ByID : ....................: OK
Save the module:3417 ByID : ....................: OK
Save the module:3421 ByID : ....................: OK
Save the module:3422 ByID : ....................: OK
Save the module:3423 ByID : ....................: ERR(Read Fail)
Save the module:3424 ByID : ....................: OK
Save the module:3425 ByID : ....................: OK
Save the module:3426 ByID : ....................: OK
Save the module:3429 ByID : ....................: OK
Save the module:3430 ByID : ....................: OK
Save the module:3431 ByID : ....................: ERR(Read Fail)
Save the module:34D1 ByID : ....................: ERR(Read Fail)
Save the module:34D2 ByID : ....................: OK
Save the module:34D3 ByID : ....................: OK
Save the module:34D4 ByID : ....................: ERR(Read Fail)
Save the module:34D5 ByID : ....................: OK
Save the module:34D6 ByID : ....................: OK
Save the module:34D7 ByID : ....................: OK
Save the module:34D8 ByID : ....................: OK
Save the module:34E7 ByID : ....................: OK
Save the module:3500 ByID : ....................: ERR(Read Fail)
Save the module:3501 ByID : ....................: OK
Save the module:3502 ByID : ....................: OK
Save the module:3503 ByID : ....................: OK
Save the module:3504 ByID : ....................: ERR(Read Fail)
Save the module:3511 ByID : ....................: OK
Save the module:3513 ByID : ....................: OK
Save the module:3514 ByID : ....................: OK
Save the module:3551 ByID : ....................: OK
Save the module:3604 ByID : ....................: OK
Save the module:3605 ByID : ....................: OK
Save the module:3700 ByID : ....................: OK
Save the module:3703 ByID : ....................: OK
Save the module:3801 ByID : ....................: OK
Save the module:3802 ByID : ....................: OK
Save the module:3803 ByID : ....................: OK
Save the module:3C00 ByID : ....................: OK
Save the module:3C10 ByID : ....................: OK
Save the module:3C11 ByID : ....................: OK
Save the module:3C20 ByID : ....................: OK
Save the module:3C21 ByID : ....................: OK
Save the module:3E00 ByID : ....................: OK
Save the module:3E01 ByID : ....................: OK
Save the module:3F00 ByID : ....................: OK
Save the module:3F01 ByID : ....................: OK
Save the module:3F03 ByID : ....................: OK
Save the module:3F04 ByID : ....................: OK
Save the module:4002 ByID : ....................: OK
Save the module:8000 ByID : ....................: OK
Save the module:8001 ByID : ....................: OK
Save the module:8002 ByID : ....................: OK
Save the module:8003 ByID : ....................: OK
Save the module:8004 ByID : ....................: OK
Save the module:8005 ByID : ....................: OK
Save the module:8006 ByID : ....................: OK
Save the module:8007 ByID : ....................: OK
Save the module:8008 ByID : ....................: OK
Save the module:8009 ByID : ....................: OK
Save the module:800A ByID : ....................: OK
Save the module:800B ByID : ....................: OK
Save the module:800C ByID : ....................: OK
Save the module:800D ByID : ....................: OK
Save the module:800E ByID : ....................: OK
Save the module:800F ByID : ....................: OK
Save the module:8010 ByID : ....................: OK
Save the module:8011 ByID : ....................: OK
Save the module:8012 ByID : ....................: OK
Save the module:8013 ByID : ....................: OK
Save the module:8014 ByID : ....................: OK
Save the module:8015 ByID : ....................: OK
Save the module:8016 ByID : ....................: OK
Save the module:8017 ByID : ....................: OK
Save the module:8018 ByID : ....................: OK
Save the module:8019 ByID : ....................: OK
Save the module:801A ByID : ....................: OK
Save the module:801B ByID : ....................: OK
Save the module:801C ByID : ....................: OK
Save the module:801D ByID : ....................: OK
Save the module:801E ByID : ....................: OK
Save the module:801F ByID : ....................: OK
Save the module:8020 ByID : ....................: OK
Save the module:8021 ByID : ....................: OK
Save the module:8022 ByID : ....................: OK
Save the module:8023 ByID : ....................: OK
Save the module:8024 ByID : ....................: OK
Save the module:8025 ByID : ....................: OK
Save the module:8026 ByID : ....................: OK
Save the module:8027 ByID : ....................: OK
Save the module:8028 ByID : ....................: OK
Save the module:8029 ByID : ....................: OK
Save the module:802A ByID : ....................: OK
Save the module:802B ByID : ....................: OK
Save the module:802C ByID : ....................: OK
Save the module:802D ByID : ....................: OK
Save the module:802E ByID : ....................: OK
Save the module:802F ByID : ....................: OK
Save the module:8030 ByID : ....................: OK
Save the module:8031 ByID : ....................: OK
Save the module:8032 ByID : ....................: OK
Save the module:8033 ByID : ....................: OK
Save the module:8034 ByID : ....................: OK
Save the module:8035 ByID : ....................: OK
Save the module:8036 ByID : ....................: OK
Save the module:8037 ByID : ....................: OK
Save the module:8038 ByID : ....................: OK
Save the module:8039 ByID : ....................: OK
Save the module:803A ByID : ....................: OK
Save the module:803B ByID : ....................: OK
Save the module:803C ByID : ....................: OK
Save the module:803D ByID : ....................: OK
Save the module:803E ByID : ....................: OK
Save the module:803F ByID : ....................: OK
Save the module:8040 ByID : ....................: OK
Save the module:8041 ByID : ....................: OK
Save the module:8042 ByID : ....................: OK
Save the module:8043 ByID : ....................: OK
Save the module:8044 ByID : ....................: OK
Save the module:8045 ByID : ....................: OK
Save the module:8046 ByID : ....................: OK
Save the module:8047 ByID : ....................: OK
Save the module:8048 ByID : ....................: OK
Save the module:8049 ByID : ....................: OK
Save the module:804A ByID : ....................: OK
Save the module:804B ByID : ....................: OK
Save the module:804C ByID : ....................: OK
Save the module:804D ByID : ....................: OK
Save the module:804E ByID : ....................: OK
Save the module:804F ByID : ....................: OK
Save the module:8050 ByID : ....................: OK
Save the module:8051 ByID : ....................: OK
Save the module:8052 ByID : ....................: OK
Save the module:8053 ByID : ....................: OK
Save the module:8054 ByID : ....................: OK
Save the module:8055 ByID : ....................: OK
Save the module:8056 ByID : ....................: OK
Save the module:8057 ByID : ....................: OK
Save the module:8058 ByID : ....................: OK
Save the module:8059 ByID : ....................: OK
Save the module:805A ByID : ....................: OK
Save the module:805B ByID : ....................: OK
Save the module:805C ByID : ....................: OK
Save the module:805D ByID : ....................: OK
Save the module:805E ByID : ....................: OK
Save the module:805F ByID : ....................: OK
Save the module:8060 ByID : ....................: OK
Save the module:8061 ByID : ....................: OK
Save the module:8062 ByID : ....................: OK
Save the module:8063 ByID : ....................: OK
Save the module:8064 ByID : ....................: OK
Save the module:8065 ByID : ....................: OK
Save the module:8066 ByID : ....................: OK
Save the module:8067 ByID : ....................: OK
Save the module:8068 ByID : ....................: OK
Save the module:8069 ByID : ....................: OK
Save the module:806A ByID : ....................: OK
Save the module:806B ByID : ....................: OK
Save the module:806C ByID : ....................: OK
Save the module:806D ByID : ....................: OK
Save the module:806E ByID : ....................: OK
Save the module:806F ByID : ....................: OK
Save the module:8074 ByID : ....................: OK
Save the module:80FC ByID : ....................: OK
Save the module:80FE ByID : ....................: OK
Save the module:80FF ByID : ....................: OK
Save the module:8FFC ByID : ....................: OK
Save the module:8FFD ByID : ....................: OK
Save the module:8FFE ByID : ....................: OK
Save the module:AC55 ByID : ....................: OK
Save the module:ADDD ByID : ....................: OK
Save the module:D000 ByID : ....................: OK
Save the module:D001 ByID : ....................: OK
Save the module:D002 ByID : ....................: OK
Save the module:D003 ByID : ....................: OK
Save the module:D004 ByID : ....................: OK
Save the module:D005 ByID : ....................: OK
Save the module:D006 ByID : ....................: OK
Module backup completed!
load 01...
load 01 to HDD RAM...
The data source : ..............................: file
C:\UserDataFile\WDC Marvell\Hubble LT\WD5000LMVW-11VEDS0-01-01A01-WD-WXB1A63f4131_p.wahyu\Data\Modules_ByID
Get 01 module from HDD : .......................: OK
Load module list : .............................: OK
Load LDR : .....................................: Err
Load 02 module to HDD RAM : ....................: OK
Open SA access ...
Get SA access information : ....................: OK
Check SA access data : .........................: OK
Open SA access : ...............................: OK
Soft reset
Soft reset
Load LDR(0x11), As permanent overlay...
Send Data(0x11) : ..............................: Err(Send Data Fail)
load 01...
The data source : ..............................: HDD
Open SA access ...
PostPosted: April 24th, 2021, 14:59
Maybe not original ROM,
Try to load Mod 02 after this
Open SA access ...
sometime it is working. Sometimes you could see 0 capacity.
I have met so many times with this case. I could look at with remote connection if you wish
Sexy Womans from your town
