HDD GURU FORUMS
http://forum.hddguru.com/
WD20NMVW-11AV3S0 User password not working
http://forum.hddguru.com/viewtopic.php?f=28&t=41242
Page 1 of 1
Author:  HddDonorMarket [ April 24th, 2021, 15:32 ]
Post subject:  WD20NMVW-11AV3S0 User password not working
WD20NMVW-11AV3S0 usb drive. Converted to sata PCB first.
accessed to drive with MRT, applied solve slow respond.
Technology mode key : ..........................: OK
RAM:
Read HDD Info : ................................: OK
Heads number : .................................: 8
Head map : .....................................: FF
SA Cyl Count : .................................: 256
Serials Mark : .................................: 0xFE16
Control version : ..............................: A5C0
Zone allocation table : ........................: OK
SA SPT : .......................................: 1480
ROM:
Read Rom Infos : ...............................: OK
ROM Data Size : ................................: 256 Kb
ROM version : ..................................: 01.0GG
ROM generation : ...............................: 01.0HG
Link table version : ...........................: 00.04
ROM Firmware version : .........................: 0001000G
ROM Modules:
Flash ROM dir reading : ........................: OK
Switched off heads : ...........................: Yes
Heads number : .................................: 0x8
Heads number in use : ..........................: 0x8
heads map : ....................................: 0,1,2,3,4,5,6,7
SA Module Dir Loading...
Load SA Module dir : ...........................: OK
Configuration reading : ........................: OK
Master Password : ..............................: has not been set
User Password : ................................: has not been set
Head 0 bad. I have imaged all other heads data fully.
User data look like encrypted. I have checked target drive in windows after clone . I saw a WD partiton end of drive
It is now working automaticly (autorun not runing when plug in drive)
User have user password. Tried decrypt with this password. but there is an error like this.
USB PCB has JMS538S
Here is Mod 25 , 02
25.rar [1.87 KiB]
Downloaded 722 times
I have searched google. Couldn't find a solution for this case. Also MRT tecnician joined . And said its WD security password. But how could decrypt this data?
What is your advices.
I dont have same model drive in my hand. I would try to find a same model drive, and clone data to it, and try to look with patient PCB.
Author:  michael chiklis [ April 24th, 2021, 16:21 ]
Post subject:  Re: WD20NMVW-11AV3S0 User password not working
MRT doesn't extract EDEK correctly from that type of encryption.
I have made a video on how to manually extract EDEK from module 25 with an hex editor.
https://youtu.be/_qrs7PgStGU
The interesting part starts from 2m 40s
Author:  HddDonorMarket [ April 24th, 2021, 18:07 ]
I have watched this video before. And tried before open tag here. And tried same thing as video again. Error same
Author:  HddDonorMarket [ April 24th, 2021, 19:26 ]
Case solved.
MRT could not decrypt this issue
http://www.phpbb.com/
