Page 1 of 2
I NEED FIRMWARE
Posted: September 10th, 2021, 7:55
by SALIM
please
8TB SEAGATE
ST8000NM0045
1RL112-002
NN02
Re: I NEED FIRMWARE
Posted: September 11th, 2021, 3:25
by SALIM
PLEASE HELP
Re: I NEED FIRMWARE
Posted: September 12th, 2021, 3:04
by reliableservice
SALIM wrote:please
8TB SEAGATE
ST8000NM0045
1RL112-002
NN02
Ideally do Post with Front and Back CLEAR IMAGE of the Drive will make EASY to help you.
Re: I NEED FIRMWARE
Posted: September 14th, 2021, 3:14
by SALIM
please now
Re: I NEED FIRMWARE
Posted: September 14th, 2021, 5:23
by einstein9
reliableservice wrote:
SALIM wrote:please
8TB SEAGATE
ST8000NM0045
1RL112-002
NN02
Am wondering how an image will help YOU here? !!! try to explain more
@SALIM
Seagate firmwares are unique for each drive (specially those new 8TB)
posting the terminal log will explain it more ...
Re: I NEED FIRMWARE
Posted: September 18th, 2021, 2:01
by SALIM
please
i think i need LDR
Re: I NEED FIRMWARE
Posted: September 18th, 2021, 4:01
by fzabkar
This could be the result of a failed or improper firmware update.
Can you upload your ROM? It may be possible to revert to a backup copy of the original firmware.
Re: I NEED FIRMWARE
Posted: September 18th, 2021, 11:30
by SALIM
to all members
please
Re: I NEED FIRMWARE
Posted: September 18th, 2021, 14:09
by Lardman
RAP and CAP are bad amongst other bits and the serial number in the SAP doesn't match the label you posted (but does match your MRT screenshot). Above my paid grade I'm afraid.
Re: I NEED FIRMWARE
Posted: September 18th, 2021, 14:36
by fzabkar
That's only half the ROM.
Following up Lardman's observation ...
https://www.seagate.com/au/en/support/warranty-and-replacements/
Your Product -- Exos 7E
Model Number -- ST8000NM0055
SerialNumber -- ZA108ZNX
Your Product -- Enterprise Capacity 3.5 Hard Drives
Model Number -- ST8000NM0045
SerialNumber -- ZA13WEXP
Re: I NEED FIRMWARE
Posted: September 18th, 2021, 14:52
by Lardman
Sloppy seconds on a fubar drive do you think?
Re: I NEED FIRMWARE
Posted: September 18th, 2021, 15:07
by fzabkar
I'm watching a thread in another forum where an ST2000VM003 drive has been relabelled as a FireCuda, and the CAP in the ROM has been hacked so that the drive reports the fake serial number.
Re: I NEED FIRMWARE
Posted: September 18th, 2021, 15:44
by Lardman
I'm following Phil's thread - I just don't see that sort of thing here or at least I don't think I do.
Given how close the 2 drives in this case are I wonder if the pcb being used is original or if it's a board swap without a rom swap.
SALIM have you don't anything to the drive/rom yet?
Re: I NEED FIRMWARE
Posted: September 18th, 2021, 16:03
by fzabkar
deleted
Re: I NEED FIRMWARE
Posted: September 18th, 2021, 16:37
by fzabkar
Could we see both sides of the PCB?
Could we see the markings on the chips, especially the ROM?
Re: I NEED FIRMWARE
Posted: September 18th, 2021, 22:48
by fzabkar
ST8000NM0045 is a standard (non-SED) 4Kn model whereas ST8000NM0055 is a standard 512e model:
EXOS Enterprise 7E8 SATA Product Manual:
https://www.seagate.com/www-content/product-content/enterprise-hdd-fam/enterprise-capacity-3-5-hdd/enterprise-capacity-3-5-hdd/en-us/docs/100827319a.pdf
MRT identifies the family for the ST8000NM0055 as MakaraPlus, so I'm guessing that the ST8000NM0045 is the 4Kn version of the same family.
These firmware updates contain LOD files (loaders):
EntCap-MakaraPlus-STD-SATA-4kN-NN04.zip
https://files.hddguru.com/download/Firmware%20updates/Seagate/EntCap-MakaraPlus-STD-SATA-4kN-NN04.zip
EntCap-MakaraPlus-STD-SATA-512E-SN05.zip
https://files.hddguru.com/download/Firmware%20updates/Seagate/EntCap-MakaraPlus-STD-SATA-512E-SN05.zip
EntCap-MakaraPlus-STD-SATA-512E-SN04.zip
https://files.hddguru.com/download/Firmware%20updates/Seagate/EntCap-MakaraPlus-STD-SATA-512E-SN04.zip
EntCap-MakaraPlus-STD-SATA-512E-PN04.zip
https://files.hddguru.com/download/Firmware%20updates/Seagate/EntCap-MakaraPlus-STD-SATA-512E-PN04.zip
Re: I NEED FIRMWARE
Posted: September 19th, 2021, 1:20
by SALIM
thanks
for all of you
Re: I NEED FIRMWARE
Posted: September 19th, 2021, 16:41
by fzabkar
MakaraPlus NN05 4Kn loader attached.
Re: I NEED FIRMWARE
Posted: October 1st, 2021, 10:40
by SALIM
SALIM wrote:please
i think i need LDR
PLEASE HELP
not solved
Re: I NEED FIRMWARE
Posted: October 1st, 2021, 16:08
by fzabkar
Why does your drive have two different serial numbers from two different models?
Why have you only uploaded half of the ROM?
Is the drive a fake?
The "Overlay ..." messages in your terminal log would suggest that your drive can reach the SA, so the adaptives would seem to be native, or am I misunderstanding something?
