| WD 2T heads issue http://forum.hddguru.com/viewtopic.php?f=28&t=41796 |
Page 1 of 1 |
| Author: | Core.iStores [ October 16th, 2021, 14:29 ] |
| Post subject: | WD 2T heads issue |
i have a WD 2T 2.5 which only gives HEAD 0 when imaging any help with that please ? |
| Author: | pclab [ October 17th, 2021, 9:49 ] |
| Post subject: | Re: WD 2T heads issue |
Probably other heads are bad. You might need to replace them. |
| Author: | Core.iStores [ October 18th, 2021, 5:58 ] |
pclab wrote: Probably other heads are bad. You might need to replace them. it gives HEAD 0 on all sectors does it mean the heads are weak ? |
| Author: | pclab [ October 18th, 2021, 9:16 ] |
What do you mean with gives Head 0? |
| Author: | Core.iStores [ October 18th, 2021, 13:24 ] |
pclab wrote: What do you mean with gives Head 0? i mean that when i do create head map with MRT it gives only HEAD 0 and when i am imaging the HDD to another it gives HEAD 0 on all sectors and it images very slow not even 1 Mbps |
| Author: | unknown [ October 18th, 2021, 13:43 ] |
What is the drive model? Charger, Shrek..etc? |
| Author: | Core.iStores [ October 19th, 2021, 1:46 ] |
unknown wrote: What is the drive model? Charger, Shrek..etc? Charger |
| Author: | unknown [ October 19th, 2021, 3:04 ] |
You are using the unlocked PCB? |
| Author: | Core.iStores [ October 19th, 2021, 13:34 ] |
unknown wrote: You are using the unlocked PCB? no i am using the original PCB |
| Author: | pepe [ October 20th, 2021, 7:15 ] |
it is highly probable that you will screw up the whole thing without proper tools and access to the SA (not possible with orig pcb, at least not without unlock server). It can erase T2 or corrupt the SA with donor heads, then bye-bye data. So i don't recommend continuing like this, especially it is a client's drive. pepe |
| Author: | Core.iStores [ October 20th, 2021, 14:05 ] |
pepe wrote: it is highly probable that you will screw up the whole thing without proper tools and access to the SA (not possible with orig pcb, at least not without unlock server). It can erase T2 or corrupt the SA with donor heads, then bye-bye data. So i don't recommend continuing like this, especially it is a client's drive. pepe thanks a lot for your reply i did not do anything with the HDD and handed it back to the client |
