 Post subject: WD10jmvw -11ajgs0 head compatibility _ DCM DCX codes
PostPosted: October 25th, 2021, 10:43
I swapped DCM HHKTJHB heads for EHKTJHKB heads and suspect they are not compatible. I am not sure which DCM letters absolutly have to match. I suspect that preamp info is represented but not sure where. This preamp info MUST match I suspect. Maybe the DCX must match in places as well. Where do I find the proper answer ... there seems to be a lot of "opinions" out there but I would like to hear from someone with real hands on experience on this.
Gordon
 Post subject: Re: WD10jmvw -11ajgs0 head compatibility _ DCM DCX codes
PostPosted: October 25th, 2021, 10:51
TJ and they are compatible. Some other attributes may still be different, like mr offset, which may result in corrupting the SA.
PostPosted: October 25th, 2021, 12:21
DCX is a secret code which identifies fakes. I have identified the meanings of 8 out of 9 characters. Basically it checks for consistency with the serial number and model number.
In short, DCX has no relevance to head swaps.
PostPosted: October 25th, 2021, 13:09
deleted
PostPosted: October 26th, 2021, 5:15
Yep, your patient and donors are compatible.
Describe the behavior after heads swap.
PostPosted: November 8th, 2021, 17:01
Not enough data. just DCM not enough
Sexy Womans from your town
Users browsing this forum: No registered users and 110 guests
