HDD GURU FORUMS
http://forum.hddguru.com/
Seagate ST9750420AS can not read after a while
http://forum.hddguru.com/viewtopic.php?f=28&t=41809
Page 1 of 1
Author:  Core.iStores [ October 20th, 2021, 14:27 ]
Post subject:  Seagate ST9750420AS can not read after a while
every thing with this drive is good and i can backup and read everything accept when i try to do logical scan or read user data it stops reading after a little while and gives red sectors you can see in the attached photo
can any when help me with this please ?
Author:  pepe [ October 20th, 2021, 15:35 ]
Post subject:  Re: Seagate ST9750420AS can not read after a while
have you checked if the unreadable area starts at a head boundary? i suspect h1 is weak (at least)
Author:  Core.iStores [ October 21st, 2021, 15:12 ]
the problem is that from that point till the end it gives red sectors even if i go to the end sector it gives all red
Author:  pepe [ October 21st, 2021, 17:18 ]
then it is probably translator related.
http://www.phpbb.com/
