 Post subject: Seagate ST9750420AS can not read after a while
PostPosted: October 20th, 2021, 14:27
every thing with this drive is good and i can backup and read everything accept when i try to do logical scan or read user data it stops reading after a little while and gives red sectors you can see in the attached photo
can any when help me with this please ?
 Post subject: Re: Seagate ST9750420AS can not read after a while
PostPosted: October 20th, 2021, 15:35
have you checked if the unreadable area starts at a head boundary? i suspect h1 is weak (at least)
PostPosted: October 21st, 2021, 15:12
the problem is that from that point till the end it gives red sectors even if i go to the end sector it gives all red
PostPosted: October 21st, 2021, 17:18
then it is probably translator related.
Users browsing this forum: No registered users and 21 guests
