| Reserved Track in SA - No UA Acessible http://forum.hddguru.com/viewtopic.php?f=28&t=41866 |
Page 1 of 1 |
| Author: | EnigmaSpace [ November 8th, 2021, 9:20 ] |
| Post subject: | Reserved Track in SA - No UA Acessible |
Attachment: WD20SDZW-11Z3CS0 , IDs Perfectly , Read/Write Modules Perfectly . But No Access to User Data . Gives Read ERR. |
| Author: | fzabkar [ November 9th, 2021, 13:21 ] |
| Post subject: | Re: Reserved Track in SA - No UA Acessible |
Just curious ... The tool is reporting the reduced capacity that would normally be seen via USB, ie 3906963632 LBAs. The full UA capacity is 3907029168. That's a difference of 65536 sectors. |
| Author: | HddDonorMarket [ November 11th, 2021, 11:22 ] |
fzabkar wrote: Just curious ... The tool is reporting the reduced capacity that would normally be seen via USB, ie 3906963632 LBAs. The full UA capacity is 3907029168. That's a difference of 65536 sectors. 256x256=65536 I dont know what does it mean |
| Author: | EnigmaSpace [ July 28th, 2025, 5:18 ] |
Hii Once again , I have got another charger drive with capacity 3906963632 , But there is some valid data recoverable, though sector zero (to some more sector) is junk . |
