 Post subject: MRT Ver 2.1.7.1 Software Update ?
PostPosted: November 3rd, 2021, 2:45
Is, The New Software update from MRTLAB is worth to update , as its changelog says it can Unlock PCBs from Charger and Splyglass (i Doubt it).
MRT data recovery software upgrade log
2nd. November 2021
The main program of MRT is updated to Ver.2.1.7.1 with the following
updates:
1. Added shortcut for creating a specified interface after selecting channels.
2. Optimized some underlying structure.
Programmer utility, upgrade to 1.0.7.1 with the following updates:
1. Added support for MRT Programmer VER 3.0.
2. Optimized SPI reading and writing stability.
Western Digital, upgrade to 2.3.7.1:
1. Added new families of 800xx series: Carmel(800077), VeniceR(810011), SPYG2ULT(810035).
2. Added WD firmware unlocking solution: Create Unlocked ROM in ROM tool, which can support mainstream laptop drives such as 800065(Chager), 800066(Palmer), 800077(Carmel), and 810011(VeniceR).
(It enables the engineer to generate unlocked ROM file by an automatic process including original ROM reading/analyzing and write-back of the unlocked ROM data)
3. Added T2(module190) editor with functions such as Obtain T2 Data, Parse T2 Data, and Edit T2 Data.
4. Added headmap in Data Explorer, which is based on T2 data, for families Carmel, VeniceR, Charger, e.t.c.
5. Added features of Repair T2 and Upload T2 Data to HDD RAM to facilitate the solutions for part of difficult HDD malfunctions such as all sectors displaying 00, automatic power off while trying to read LBA, and bootup failure due to module 190.
6. Added the feature of Exchange commands & unlock in ROM tool and shortcut button, which requires the assistance of serial ports and ROM data unlocked by MRT.
7. Added function that allows manual input of the module ID and processes read and write.
8. Added seperate ROM ID for entire ROM in ROM module list.
9. Added Serial port connection/disconnection buttons to the tool bar.
10. Added Log/Terminal, COM Switch buttons to family panel and power on/off icon to WD shortcut button bar.
11. Optimized the feature of Remove HDD password.
12. Optimized ROM writing to support new HDDs with large ROM size.
13. Optimized family interface by adding the exclusive page for 800xx series.
14. Optimized Edit HDD ID in RAM.
15. Optimized the underlying database structure.
16. Optimized Logcal Scan function that it will display speed.
17. Optimized database engine to avoid JET database engine error.
18. Optimized the function of saving modules in batches.
Seagate F3, update to 2.0.7.0:
1. Added MCMT parse function.
2. Added MCMT edit function.
3. Added MCMT Extent edit function.
4. Added Firmware Unlock for family 97.
5. Added support of transfering defects into P-list for family 58: ST3000DM001-1ER166, ST2000DM001-1ER164, ST1000DM001-1ER162, ST500DM002-1ER14C, ST1000DM001-1CH162, and ST2000DM001-1CH164.
6. Added support of file dragging to Virtual Start dialog box.
8. Added buttons of Selecting Copy0 and Copy1 to dialog box of Backup sys file feature.
9. Added customization of Default baud rate/voltage selection.
10. Added filtering scheme to Backup sys file feature.
11. Optimized sys file description display of 5400.6.
12. Optimized default selected options of Backup sys file feaature for 5400.6.
14. Optimized selection strategy of Exchange Commands switch-over on the main interface(shortcut button on the right side) .
15. Optimized Edit HDD ID in RAM by adding an initialization error reminder.
16. Optimized capcaity display issue in some disks after editing HDD ID in Service Area Tools.
17. Optimized the mechanism of sys file backup to exclude the reading of sys files other than Volume 0, Volume 3.
18. Optimized underlying database structure.
19. Optimized G-list entry unfolding.
20. Optimized disk information configuration that is documented in folder Configure.
21. Optimized CAP modification with regard to capacity that is expanded to be more than 2T.
Data Explorer, upgrade to Ver.6.0.0.4:
1. Added the following RAW data scanning formats:
For media: FLV, MP4, MP3, AVI, WAV, MKV, RM, AIFF, MIDI
For files: PPTX, XLSX
2. Optimized the speed for marking the valid data in partition.
3. Optimized the underlying architecture to facilitate user experience.
4. Optimized user operation verification to reduce logic errors.
5. Optimized File index creation and access speed.
6. Added internal commissioning to assist locating issues.
7. Fix a bug of the size of the file to be saved.
Phison modules are upgraded to ver.1.0.7.0:
1. Added uploading LDR support of AS2258(PS3111).
2. Added virtual translator strategy for AS2258(PS3111).
3. Added parsing for categories such as Type of new chips
4. Optimized the underlying architecture of PS modules.
5. Optimized read and write firmware function.
6. Optimized read and write CP function.
 Post subject: Re: MRT Ver 2.1.7.1 Software Update ?
PostPosted: November 3rd, 2021, 13:34
https://forum.hddguru.com/viewtopic.php?f=28&t=41721&p=293864#p293864
PostPosted: November 4th, 2021, 5:05
As the log says, it can unlock Palmer, Charger, Venice and Carmel, but it can't unlock Spyglass( not need), Spayglass2 amd Spyglass2ultra. Probably in the future update Spyglass2(Ultra) family will be added.
Rgds
www.datasave.ro
PostPosted: March 4th, 2022, 4:50
Where are these functions in MRT 2.1.7.x ? I can't find them
PostPosted: March 26th, 2022, 1:11
Here
PostPosted: March 27th, 2022, 8:54
EnigmaSpace wrote:
Here
Thankyou
