| WD4005FZBX-00K5WB0 - Firmware unlock http://forum.hddguru.com/viewtopic.php?f=28&t=42478 |
Page 1 of 1 |
| Author: | IntratecDR [ June 6th, 2022, 3:47 ] |
| Post subject: | WD4005FZBX-00K5WB0 - Firmware unlock |
Hi, I have a fairly new WD drive which seems to have a locked firmware. PCB version is 004-0836131. Is there a way to unlock this firmware? MRT does not support this version. Thank you. |
| Author: | Amarbir[CDR-Labs] [ June 6th, 2022, 5:19 ] |
| Post subject: | Re: WD4005FZBX-00K5WB0 - Firmware unlock |
IntratecDR wrote: Hi, I have a fairly new WD drive which seems to have a locked firmware. PCB version is 004-0836131. Is there a way to unlock this firmware? MRT does not support this version. Thank you. Well , Show us a picture please |
| Author: | E123 [ June 6th, 2022, 9:33 ] |
This drive is not WD ROYL but HGST CCB architecture. |
| Author: | Amarbir[CDR-Labs] [ June 6th, 2022, 11:08 ] |
Well, This is Hitachi Arch As The Gentlemen Above Said |
| Author: | fzabkar [ June 6th, 2022, 13:35 ] |
The PCB is 0B36131. WD PCBs begin with "2060-". HGST PCBs begin with "0A" or "0B". WD's warranty checker ... https://support-en.wd.com/app/warrantystatusweb ... identifies the drive as ...
WDVL6 7200 256M SATA3 6GB/S 4.0 TB 6HD STD HGST I think the family could be Vela (Vela-6 ?). US7SAN6T0 is an Ultrastar DC HC310. https://documents.westerndigital.com/content/dam/doc-library/en_us/assets/public/western-digital/product/data-center-drives/ultrastar-dc-hc300-series/product-manual-ultrastar-dc-hc310-sata-oem-spec.pdf Another clue is in the leading characters of the WWN (which you have obscured). |
| Author: | IntratecDR [ June 7th, 2022, 5:20 ] |
Thank you all. |
| Author: | IntratecDR [ June 9th, 2022, 3:58 ] |
Thank you all, Ive done some research and cant find a way to unlock this drive. we have confirmation it's locked. any ideas will be appreciated. |
| Author: | IntratecDR [ June 9th, 2022, 7:00 ] |
Can anyone point me where to find uploaded firmware//modules for this drive? |
