 Post subject: HGST HTS541010B7E610 - MRT Any support for such model ?
PostPosted: June 10th, 2022, 5:44
HGST HTS541010B7E610 - MRTLAB any support for such model ?
1TB Laptop Hard drive.
or How to Recovery data from Un-supported Model ?
Selected family:Basic access method
Model:HGST HTS541010B7E610
Technology key : ....................................Error
Probing Technology Key......
Tech-Key detection : ................................Error
Reading module list failed,try Copy1......
Read module list : ..................................Error
Read open module list : .............................Error
get the head number : ...............................Error
 Post subject: Re: HGST HTS541010B7E610 - MRT Any support for such model ?
PostPosted: June 10th, 2022, 9:47
that's a wd palmer drive, so use wd util, and you will need either an unlocked pcb or unlock patient rom using MRT unlock function (which i have perfectly no idea coz i don't have mrt, just know it should be possible)
PostPosted: June 10th, 2022, 10:36
Thanks for the Reply.
Yes I did,
but unlock working for ROM transfer.
Technology mode key : ..........................: OK
RAM:
Read HDD Info : ................................: OK
Heads number : .................................: 2
Head map : .....................................: 0
SA Cyl Count : .................................: 512
Serials Mark : .................................: 0xFE16
Control version : ..............................: 5460
Zone allocation table : ........................: OK
SA SPT : .......................................: 1944
ROM:
Read Rom Infos : ...............................: Err
ROM Modules:
Flash ROM dir reading : ........................: Err
Read 0A module : ...............................: Err
Load SA translator : ...........................: Err
Once Again Thanks.
