Facing typical issue with MRT ULTRA CARD. (serial usb)
Posted: October 19th, 2022, 10:51
by reliableservice
MRT Ultra Version 2.1.5.3
any Seagate Hdd i connect it doesn't give me ROM access or doesn't read via serial port.
MRT USB TERMINAL (ATTACH IS PHOTO)
Normal hdd is attached photo
ST3500325AS | 500 GB
-------------------------------LOG
Identifying device...
model:ST9500325AS firmware version:0002BSM1 serial number:6VE668LD
Getting detailed firmware version...
WY05D7.BSM1.DA99L1.0002BSM1
SMP Dbl: 0x3C000317 - 0x037FF7FF
Disk cache reserve size: 0x0
physical sector size of user sector : ..............512 Bytes
physical sector size of service area : .............512 Bytes
Number of physical heads : .........................4
Get System module information ...
ID length Description
00 2
01 2
02 16
03 1870
04 9
05 4
06 85
07 1
08 2400
09 1
0A 2251
0B 1000
0C 64000
0D 160
0E 432
0F 223
13 8
15 100
16 2
17 40
19 24
1A 33
1B 1
1C 9
1D 128
1E 128
1F 640
22 80
23 80
24 80
25 80
26 80
27 80
28 80
29 80
2A 9
2B 535
2C 432
2D 432
2E 432
2F 432
30 432
31 432
32 432
33 4576
34 640
35 26
Finished to get system module information!
Getting DT information...
ROM:
ID Offset address Length
00 06020100 43520
01 06020000 256
04 04000000 4096
05 0006C000 81920
08 10070000 948
0A 060A1720 1024
12 100D4000 104
13 060AC7A0 768
14 060ACAA0 64
15 00000000 524288
1B 060AB588 4632
1C 060AB448 320
1D 06020120 208
1E 06020380 3216
RAM:
ID offset address length
00 06020100 43520
01 06020000 256
02 060201F0 400
04 04000000 4096
05 0006C000 81920
06 00227840 40996
08 10070000 948
0A 060A1720 1024
12 100D4000 104
13 060AC7A0 768
14 060ACAA0 64
15 00000000 524288
16 06020100 32
17 06022A60 1616
1B 060AB588 4632
1C 060AB448 320
1D 06020120 208
1E 06020380 3216
1F 06144678 1728
20 06144D38 72
Finished to get DT information!
Getting service area size.......
Service area size: : ................................Fail
Getting list of sys files.......
Serial port error!
Reading autotuning buffer
Buff Root FAT searching in RAM : ...................OK
Searching module table in RAM : .....................OK
Searching DT table(RAM, WR) in RAM : ................OK
Searching DT table(RAM, RD) in RAM : ................OK
Searching volume 0 file table in RAM : ..............OK
Searching volume 1/2 file table in RAM : ............FAIL
Searching volume 3 file table in RAM : ..............FAIL
SERIAL PORT ERROR AND NOT READING service area.
even while reading ROM it fails via bootcode.
even ctrl-z doesn't work in terminal mode.
what is problem
Re: Facing typical issue with MRT ULTRA CARD. (serial usb)
Posted: October 20th, 2022, 11:11
by michael chiklis
If i remember well, few years ago i had same issue.
I replaced the terminal adapter and problem solved. Probably your adapter is faulty.
