 Post subject: WDC WD5000AAKS-75V0A0 - Don't work as SATA Read but by COM
PostPosted: December 22nd, 2022, 2:01
HDD Model : WDC WD5000AAKS-75V0A0
PCB No: 2060-701640-002 REV A
500 GB SATA.
What I need it should get ready and work as SATA and not via Com port.
It doesn't work in WDC Marvel - Menu mode
It works in WDC Marvel Com port - Menu mode
Following is LOG and Attached Images for Refrence.
Technology mode key : ..........................: OK
RAM:
Read HDD Info : ................................: OK
Heads number : .................................: 2
Head map : .....................................: 3
SA Cyl Count : .................................: 256
Serials Mark : .................................: 0xEC16
Control version : ..............................: 63B0
Zone allocation table : ........................: OK
SA SPT : .......................................: 1290
ROM:
Read Rom Infos : ...............................: OK
ROM Data Size : ................................: 192 Kb
ROM version : ..................................: 12.1RD
ROM generation : ...............................: 12.1SD
Link table version : ...........................: 04.09
ROM Firmware version : .........................: 0012001R
ROM Modules:
Flash ROM dir reading : ........................: OK
Switched off heads : ...........................: Yes
Heads number : .................................: 0x2
Heads number in use : ..........................: 0x2
heads map : ....................................: 0,1
Load SA translator : ...........................: OK
SA Module Dir Loading...
Load SA Module dir : ...........................: OK
Configuration reading : ........................: OK
Master Password : ..............................: has not been set
User Password : ................................: has not been set
