WD WD10EURX-61UY4Y0,Trailxlb, Logical Scan Test failed
http://forum.hddguru.com/viewtopic.php?f=28&t=43118
Page 1 of 2
Author:  KangKung [ February 11th, 2023, 0:48 ]
Post subject:  WD WD10EURX-61UY4Y0,Trailxlb, Logical Scan Test failed
I have problem with WD WD10EURX-61UY4Y0,Trailxlb, 1Tb.
SA, Hdd resources, read and saved > OK
User sector viewer > OK
Head test, min sectors to max sectors> OK
Logical scan test > FAILED , as in attachment pics, from LBA 0 to max LBA 1953525168 , it is remain same problem.
How to fix this issue?
Thank you.
File comment: WD WD10EURX-61UY4Y0,Trailxlb, Logical Scan Test failed
Author:  fzabkar [ February 11th, 2023, 18:55 ]
Post subject:  Re: WD WD10EURX-61UY4Y0,Trailxlb, Logical Scan Test failed
WD's warranty checker identifies the drive as "ARRIS CE".
https://support-en.wd.com/app/warrantystatusweb
Arris is a manufacturer of video surveillance equipment:
https://en.wikipedia.org/wiki/Arris_International
I expect that your drive has been firmware locked.
Author:  KangKung [ February 13th, 2023, 22:31 ]
As I described that SA, Hdd resources, read and saved with no issue, that means all those hdd firmware are opened and saved.
My problem is in user area not service area/SA/Firmware.
Author:  fzabkar [ February 13th, 2023, 23:31 ]
Can you upload the resources?
Author:  KangKung [ February 13th, 2023, 23:45 ]
Hi fzabkar,
Here is hdd resources, in attachment all those hdd resources
Technology mode key : ..........................: OK
RAM:
Read HDD Info : ................................: OK
Heads number : .................................: 2
Head map : .....................................: 3
SA Cyl Count : .................................: 256
Serials Mark : .................................: 0xFE16
Control version : ..............................: 5511
Zone allocation table : ........................: OK
SA SPT : .......................................: 1575
ROM:
Read Rom Infos : ...............................: OK
ROM Data Size : ................................: 256 Kb
ROM version : ..................................: 01.86R
ROM generation : ...............................: 01.87R
Link table version : ...........................: 01.0P
ROM Firmware version : .........................: 00010086
ROM Modules:
Flash ROM dir reading : ........................: OK
Switched off heads : ...........................: Yes
Heads number : .................................: 0x2
Heads number in use : ..........................: 0x2
heads map : ....................................: 0,1
Load SA translator : ...........................: OK
SA Module Dir Loading...
Load SA Module dir : ...........................: OK
Configuration reading : ........................: OK
Master Password : ..............................: has not been set
User Password : ................................: has not been set
WDC WD10EURX-61UY4Y0-01.01A01-WD-WCC4J1CEXKX7-00010086.7z [5.5 MiB]
Downloaded 596 times
Author:  KangKung [ February 14th, 2023, 5:31 ]
RE-write ROM modules and proceed DE.
It is now DE imaging is works , but in very slow speed 300-500kb/sec only.
Possible the heads weak?
Author:  pepe [ February 14th, 2023, 5:33 ]
is the speed the same on all heads?
Author:  KangKung [ February 14th, 2023, 5:38 ]
Yes H0 and H1 same speed
Author:  KangKung [ February 14th, 2023, 6:23 ]
Bad luck... it is stop and error to DE :( :(
Author:  KangKung [ February 14th, 2023, 6:28 ]
Strange, head test min and max sector no issue
Head Test... sector 1
Head: 0 Write data : ..........................: OK
Head: 0 Read data : ...........................: OK
Head: 1 Write data : ..........................: OK
Head: 1 Read data : ...........................: OK
Head Test... sector 1575
Author:  KangKung [ February 14th, 2023, 6:31 ]
User sector viewer, begin to end no issue
Author:  KangKung [ February 14th, 2023, 9:03 ]
Logical scan test remain failed :(
Author:  fzabkar [ February 14th, 2023, 10:44 ]
The drive is degraded. Did you execute the "slow responding" fix?
ID  Flg   Cur  Wor  Thr  Raw             Description
  1   2F   186  186  186  0000000000499B  Raw Read Error Rate
  3   27   134  133    0  000000000010CC  Spin Up Time
  4   32   100  100    0  000000000001EF  Start/Stop Count
  5   33   147  147    0  000000000008E7  Reallocated Sector Count
  7   2E   200  200  200  00000000000000  Seek Error Rate
  9   32    78   78    0  00000000003F02  Power-On Hours Count
10   32   100  100    0  00000000000000  Spin Retry Count
11   32   100  100    0  00000000000000  Drive Calibration Retry Count
12   32   100  100    0  000000000000A0  Drive Power Cycle Count
183  *B2   100  100    0  00000000000000  SATA Downshift Error Count
184  *B2   100  100    0  00000000000000  End to End Error Det/Corr Count
187  *B2     1    1    0  00000000003F2E  Reported Uncorrectable Errors
188  *B2    99   97    0  00000400040004  Command Time Out
190  *A2    71   47    0  0000000000001D  Airflow Temperature
192   32   200  200    0  00000000000063  Emergency Retract Cycle Count
193   32   200  200    0  0000000000018C  Load/Unload Cycle Count
194   22   114   90    0  0000000000001D  HDA Temperature
195  *B6   200  200  200  00000000000000  ECC on the Fly Count
196   32   176  176    0  00000000000018  Reallocated Sector Event
197   32   200  200    0  00000000000064  Current Pending Sector Count
198   30   100  253    0  00000000000000  Offline Uncorrectable Sector Count
199   32   200  200    0  00000000000000  UltraDMA CRC Error Rate
200   08   100  253    0  00000000000000  Multi Zone Error Rate
240  *B2    79   79    0  00000000003E35  Head Flying Hours
241  *B2   200  200    0  00000882D70F90  Total LBAs written
242  *B2   200  200    0  000001D8E6B1E6  Total LBAs read
     * = hidden attribute
Author:  KangKung [ February 15th, 2023, 5:43 ]
Hi fzabkar,
Let me try, I will get back the result
Author:  KangKung [ February 15th, 2023, 5:58 ]
Hi fzabkar,
Unfortunately "slow responding" not fix the issue, Logical scan test remain failed.
Those below test are pass :
SA strucure test >> pass
Hardware modules test >> pass
Head 0/1 test >> pass (min to max sectors)
User sectors viewer > pass (min to max LBA)
Author:  KangKung [ February 15th, 2023, 6:04 ]
Or it may any special option should I select in "slow response pop up menu"? I just select as it is.
Author:  fzabkar [ February 15th, 2023, 15:46 ]
Repair by 802E/802F is not an option since both modules are empty.
I would think that you should tick all the Repair Options boxes, but I'm not a pro.
I would dump the SA again after applying this fix.
Author:  KangKung [ February 15th, 2023, 23:34 ]
Hi fzabkar, Spildit..
I will proceed all your suggestion.
I also suspected that hdd load wrong data into the RAM.
I will get back for result.
Author:  KangKung [ February 16th, 2023, 5:09 ]
Spildit wrote:
I would empty the re-lo table for sure. That one is loaded to RAM causing the slow down. Your report show sectors pending reloaction so your re-lo list have entries so the drive is processing those and getting stuck and slow.
Also it's not a repair and it's not by ID ... It simply read/write module 02 (aparently by ID) and patch it. At any rate select by ID and tick the 4 boxes on repair options.
Power off/on. IMAGE THE DRIVE if possible by heads and check if some of them read faster than the others and if some have errors, etc ...
Spildit,
Module 2 how to patch in MRT? I am not found to do it in MRT.
Author:  michael chiklis [ February 16th, 2023, 6:59 ]
yes, you've to tick all 4 box in "repair options"
Page 1 of 2 All times are UTC - 5 hours [ DST ]
