| WD20EFRX-68EUZN0 2Tb, spin up spin down, no access to SA http://forum.hddguru.com/viewtopic.php?f=28&t=43153 |
Page 1 of 1 |
| Author: | lcoughey [ February 23rd, 2023, 8:20 ] |
| Post subject: | Re: WD20EFRX-68EUZN0 2Tb, spin up spin down, no access to SA |
If it spins down, that usually implies dead heads. |
| Author: | northwind [ February 24th, 2023, 3:42 ] |
+1, most probably heads are gone. |
| Author: | KangKung [ February 24th, 2023, 6:18 ] |
Hi, lcoughey, northwind I will replace the head, will get back for the result. Thank you |
| Author: | KangKung [ March 27th, 2023, 23:05 ] | ||
| Post subject: | Re: WD20EFRX-68EUZN0 2Tb, spin up spin down, no access to SA | ||
Hi, lcoughey, northwind Problem [SOLVED] You are right, after replaced head with same model, SA accessible and DE done very well. Thank you, hope useful for others also..
