Removing ---Mrt UnLock---
http://forum.hddguru.com/viewtopic.php?f=28&t=43264
Author:  LostDataSa [ April 8th, 2023, 19:48 ]
Post subject:  Removing ---Mrt UnLock---
Hi
I got ST500DM009 and in terminal: ---Mrt UnLock--- it seems the customer took it to another lab that used MRT
Can someone help me remove the Unlock and restore the original ROM so i can use PC3000
ROM.zip [406.15 KiB]
Downloaded 577 times
Author:  fzabkar [ April 8th, 2023, 22:28 ]
Post subject:  Re: Removing ---Mrt UnLock---
What about using this ROM to restore it?
https://firmware.hddsurgery.com/dl.php?file=20714&filename=ST500DM009-2F110A-CC43-ZA49BKZA.zip
You could patch your drive's adaptives into the donor. Hopefully the code is compatible with the SA.
Author:  michael chiklis [ April 8th, 2023, 22:34 ]
I deleted the fw unlock code with my mrt.
Here's the file:
MRT ROMChange.zip [399.35 KiB]
Downloaded 610 times
MRT SCREEN
Author:  LostDataSa [ January 18th, 2024, 19:31 ]
Here's the file:
thanks
