WD10EZEX-00WN4A0 track 0 bad , possible to DE?
http://forum.hddguru.com/viewtopic.php?f=28&t=43317
Author:  KangKung [ May 4th, 2023, 5:33 ]
Post subject:  WD10EZEX-00WN4A0 track 0 bad , possible to DE?
I have WD 1Tb, WD10EZEX-00WN4A0.
HDD ready, take time/slow to RDY, SA is accessible. Head test, Head 0 error to read. SA structure test, found some of SA modules error as in pic, I collected error modules only.
Since Head 0 error to read, replaced the head unit with same hdd donor, problem remain. I wonder, the head from donor, when I returned to donor hdd, now donor hdd having same issue as patient.
My question is track 0 bad , possible to DE? Beside patient platter damage donor head due to patient track 0 is bad? Physically, no scratch on platter.
Thanks for help.
Author:  pepe [ May 4th, 2023, 6:39 ]
Post subject:  Re: WD10EZEX-00WN4A0 track 0 bad , possible to DE?
if donor heads got damaged, then almost surely there is some surface problem on side0.
A SW-only solution won't solve this problem...
Author:  KangKung [ May 6th, 2023, 1:02 ]
hi Pepe,
Yes, patient hdd platter on track 0 it may damage and if any head that try to read it will be spoiled.
So, no chance to recover user data/DE.
Thank you
Author:  michael chiklis [ May 6th, 2023, 13:02 ]
could it happen due to lower (or instable) spindle speed caused by partial seizure?
In this scenario i would aspect micro scratches on surface and head will get damaged.
