Corrupted data (PDF, SLXS) after recovery with MRT
http://forum.hddguru.com/viewtopic.php?f=28&t=43324
Author:  Adam112255 [ May 7th, 2023, 20:27 ]
Post subject:  Corrupted data (PDF, SLXS) after recovery with MRT
WD 10SPZX no physical damage it started working very slow. the client need certain files which I used MRT file explorer to find and save but most of the pdf and SLXS are corrupted and can not be opened. I was wondering if there is a way to repair them. I tried to open some of them with HxD and this is what I got.
will cloning the hard drive to another hard drive fix this problem?
Author:  einstein9 [ May 8th, 2023, 3:09 ]
Post subject:  Re: Corrupted data (PDF, SLXS) after recovery with MRT
The 2nd file header seems to me its an excel file (healthy), but the file has a PDF extension
rename & try
Author:  pepe [ May 9th, 2023, 17:01 ]
perhaps drive reads from wrong location, so file repair will fail coz there is probably no good data in these files at all...
Author:  fzabkar [ May 9th, 2023, 18:06 ]
The "PK" signature denotes compression. What does 7Zip say when you try to open your file?
Author:  Arch Stanton [ May 9th, 2023, 19:25 ]
https://www.disktuna.com/repair-fix-a-c ... -write-up/
I have used the method with XLSX files too, assuming it's what you actually mean by SLXS.
Author:  Adam112255 [ May 11th, 2023, 6:40 ]
rename & try
Thanks for the suggestion but unfortunately it didn't work. probably i need to fix the slow response issue and clone it.
Author:  Adam112255 [ May 11th, 2023, 6:41 ]
yes I agree with you.
Author:  Adam112255 [ May 11th, 2023, 6:42 ]
Arch Stanton wrote:
https://www.disktuna.com/repair-fix-a-corrupt-word-document-quick-write-up/
Thanks for the help. tried it on different files but no luck.
Author:  Arch Stanton [ May 11th, 2023, 16:24 ]
So then you need to recover them again and correctly this time.
