 Post subject: WD 10SPZX super slow
PostPosted: May 11th, 2023, 6:28
Banned User
WD 10SPZX responds very slow, it spins no clicking sound and connect to MRT shows HDD information also can open file explorer in MRT and see all the files and view them but when we try to clone it to another hard drive it copies super slow. already unlocked the ROM and MRT support had a look said head 1 is weak but I tried to test the heads in MRT and both passed with OK.
any help would be appreciated
Technology mode key : ..........................: OK
RAM:
Read HDD Info : ................................: OK
Heads number : .................................: 2
Head map : .....................................: 0
SA Cyl Count : .................................: 512
Serials Mark : .................................: 0xFE16
Control version : ..............................: 5460
Zone allocation table : ........................: OK
SA SPT : .......................................: 1944
ROM:
Read Rom Infos : ...............................: OK
ROM Data Size : ................................: 1024 Kb
ROM version : ..................................: 02.1AP
ROM generation : ...............................: 02.0HP
Link table version : ...........................: 01.3C
ROM Firmware version : .........................: 0002000P
ROM Modules:
Flash ROM dir reading : ........................: OK
Switched off heads : ...........................: Yes
Heads number : .................................: 0x2
Heads number in use : ..........................: 0x2
heads map : ....................................: 0,1
Load SA translator : ...........................: OK
Number of reserved tracks in SA : ..............: 0x9
SA Module Dir Loading...
Load SA Module dir : ...........................: OK
Configuration reading : ........................: OK
Master Password : ..............................: has not been set
User Password : ................................: has not been set
Head Test...
Head: 0 Write data : ..........................: OK
Head: 0 Read data : ...........................: OK
Head: 1 Write data : ..........................: OK
Head: 1 Read data : ...........................: OK
Start Solve...
Cheack Head Data And CheckSum : ................: OK
Write Data : ...................................: OK
Start Solve...
 Post subject: Re: WD 10SPZX super slow
PostPosted: May 11th, 2023, 11:35
MRT head test when is ok just means that heads are still alive.
So it doesn't mean head 1 is in good condition, that head can be weak as MRT support tech told you.
Weak heads do read slowly or read badly in many zones.
My firmware database:
