HDD GURU FORUMS
http://forum.hddguru.com/
WD40NDZW No Disk Information
http://forum.hddguru.com/viewtopic.php?f=28&t=43426
Page 1 of 1
Author:  Adam112255 [ June 19th, 2023, 22:50 ]
Post subject:  WD40NDZW No Disk Information
WD40NDZW always busy, tried to unlock the firmware and it came out of busy mode but no disk information. any suggestions?
Author:  Adam112255 [ June 22nd, 2023, 22:23 ]
Post subject:  Re: WD40NDZW No Disk Information
Problem solved by swapping heads and loading LDR.
If anyone had a problem after unlocking firmware still can't read ROM and RAM and came up with error then you need to go to MRT main screen then Tools >> Standby/Reset/Speed >> Transmission and reset for SATA Controller then Change SATA 3 to SATA 2 and it will fix the problem.
http://www.phpbb.com/
