 Post subject: WD40NDZW No Disk Information
PostPosted: June 19th, 2023, 22:50
Banned User
WD40NDZW always busy, tried to unlock the firmware and it came out of busy mode but no disk information. any suggestions?
 Post subject: Re: WD40NDZW No Disk Information
PostPosted: June 22nd, 2023, 22:23
Banned User
Problem solved by swapping heads and loading LDR.
If anyone had a problem after unlocking firmware still can't read ROM and RAM and came up with error then you need to go to MRT main screen then Tools >> Standby/Reset/Speed >> Transmission and reset for SATA Controller then Change SATA 3 to SATA 2 and it will fix the problem.
