| Mrt Ultra pio write speed issue http://forum.hddguru.com/viewtopic.php?f=28&t=43646 |
Page 1 of 1 |
| Author: | snmir [ September 8th, 2023, 13:38 ] |
| Post subject: | Mrt Ultra pio write speed issue |
Hi, I recently got an mrt ultra card, and the pio write speed reaches 40 MB per second without changing in the default conditions, but my colleague has a speed of 80 MB per second with the same conditions and the same hard drive! I talked to the mrt support team and they couldn't fix the problem and sent me a new card, but the conditions are still the same and it didn't affect the speed! I tested with a newer system with Asus prime b760m-k motherboard with intel 12400 CPU, the speed is not more than 27 megabytes per second! Do you have any comments? My windows is 11 pro and I have 8 GB of RAM |
| Author: | snmir [ September 8th, 2023, 14:02 ] |
| Post subject: | Re: Mrt Ultra pio write speed issue |
I forgot to say that my colleague has his own card, which is an mrt ultra! |
| Author: | fzabkar [ September 8th, 2023, 15:17 ] |
I would think that the motherboard chipset is the limiting factor in PIO mode. You didn't say which motherboard your colleague has, unless "same conditions" implies identical computer hardware and OS. |
| Author: | snmir [ September 9th, 2023, 9:31 ] |
This is the specification of my colleague's system : Amd Ryzeb 5 2400G Asus TUF b450-plus gaming I tested it on two other computers and it was the same problem again, the interesting thing is that they were all Intel based! |
| Author: | Jirbun [ September 9th, 2023, 13:18 ] |
snmir wrote: I tested it on two other computers and it was the same problem again What did you test? Your hdd with friend computer+friend mrt card as was implied from your words before? How about install colleague mrt on your system or vice versa? You should get an answer in this situation. |
| Author: | fzabkar [ September 9th, 2023, 16:37 ] |
Microsoft/Intel/AMD drivers? |
