HDD GURU FORUMS
http://forum.hddguru.com/
WD40NDZW-11BCSS0 Clicking, spin down, please help.
http://forum.hddguru.com/viewtopic.php?f=28&t=44560
Page 1 of 1
Author:  KangKung [ August 7th, 2024, 4:59 ]
Post subject:  WD40NDZW-11BCSS0 Clicking, spin down, please help.
I got WD40NDZW-11BCSS0 4Tb USB, previously hdd not dropped or any impact on it, just suddenly clicking and spin down.
Unlock ROM and convert PCB to SATA (use native PCB), problem remain.
Open the lid and confirmed the heads in good condition.
Any suggestions ?
Many thanks.
Author:  digisupport [ August 7th, 2024, 8:46 ]
Post subject:  Re: WD40NDZW-11BCSS0 Clicking, spin down, please help.
Check heads in a working donor drive..
Then you know..
Author:  Amarbir[CDR-Labs] [ August 7th, 2024, 9:06 ]
Any suggestions ?
Many thanks.
Yes ,
It could be a secondary translator ,Block SA Disable 411 ,Read Mod 190 in ABA Mode ,Report Here
Author:  KangKung [ August 8th, 2024, 3:09 ]
digisupport ; I am still looking for donor.
Amarbir[CDR-Labs], as I told that drive spinning and spin down, so I unable to block 411.
Author:  KangKung [ August 12th, 2024, 8:36 ]
Applied Equalizer 810035 ;
Disable 411
Load mod 01 from donor file into RAM
This time SA can be saved(just lucky?).
A little confusing, occasionally access to SA and load SA dir smootly.
But sometimes error to load SA dir and SA.
T2 is no issue as pics?
I guest heads really having problem and need to replace.
http://www.phpbb.com/
