ST4000LM024-2AN17V Seagate 4Tb F/W 0001,Ready with Spin Down
http://forum.hddguru.com/viewtopic.php?f=28&t=44584
Author:  KangKung [ August 16th, 2024, 3:34 ]
Post subject:  ST4000LM024-2AN17V Seagate 4Tb F/W 0001,Ready with Spin Down
I got ST4000LM024-2AN17V Seagate 4Tb F/W 0001, problem is HDD ready with spin down.
ROM unlock succeeded in boot code mode, but no access into terminal as drive already spin down
Any idea how to do with MRT?
Author:  KangKung [ August 16th, 2024, 5:18 ]
Post subject:  Re: ST4000LM024-2AN17V Seagate 4Tb F/W 0001,Ready with Spin
On terminal have messages :
Boot 0x80MMD00440001
SpinUp
FAIL Servo Op=0100 Resp=0007
0100 9000 0000 0001 0000 9015 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
ResponseFrame 1A80 0000 0000 E0C0 0000 0000 0000 0000 0E9E 0000 CE00 0000 3BA7 3118 0005 0100 8551 FFFF 2000 0000 0000 0505 0003 1EBF 0000 C350 0000 0000 0020 2247 001D 0005 0000 Loop=2247Motor startedHeads loaded
ResponseFrame 1B40 0000 0000 E0C0 0000 0000 0000 0000 0E9E 0001 CE00 0000 3C9E 32D8 0005 0100 8551 FFFF 2000 0000 655F 0505 0000 C350 0000 C350 0000 0000 0020 2247 001D 0005 0000 Loop=2247Motor startedHeads loaded
Author:  Lardman [ August 16th, 2024, 5:25 ]
You're going to need a new set of heads on that.
Author:  KangKung [ August 16th, 2024, 5:59 ]
Hi Lardman,
Just edit and made Max Heads 0 in the ROM, and write the ROM, having below on terminal while head no more spin down.
Yes, I am also consider for replace the heads, I am still looking for the correct donor.
RECOV Servo Op=0100 Resp=0005
SpinUp
TCC:001F
RECOV Servo Op=0195 Resp=0005[LBA=0x00017DC3]N02020C20o0o0o0o0o0o0o0o0[LBA=0x00017DC3]NO1111102020C20o0o0o0o0o0o0o0o01111102020C20o0o0o0o0o0o0o0o01111102010C20o0o0o0o0o0o0o0o01111102020C20o0o0o0o0o0o0o0o01111102020C20o0o0o0o0o0o0o0o01111101020C20o0o0o0o0o0o0o0o01111102020C20o0o0o0o0o0o0o0o01
SIM FileFD=FC000000 ErrorCode=43160080 DiscLBA=0000000000017DC3 Duration=000006BA ms
RECOV Servo Op=0095 Resp=0005[LBA=0x0000940F]N
Trans
Rst 0x80MMD00440001
DSC PASS
(P) SATA Reset
SIM Error 1002 LBA 000000000002F724 FD FCFFF3FF
RW Error 44090081
RECOV Servo Op=01A5 Resp=0005
MCMainPOR: Start:
Media Cache Data Base 01D1CB56D8
Check MCMT Version: Current
SIM FileFD=FC3BA348 ErrorCode=43160080 DiscLBA=0000000000024B16 Duration=0000076B ms
RECOV Servo Op=0495 Resp=0005
Starting LBA of RW Request=003A944041 Length=00000003
ProcessRWError -Read- at LBA 003A944041 Sense Code=43160080
RECOV Servo Op=0595 Resp=0005
RECOV Servo Op=0495 Resp=0005Out:
InitiateMarkPendingReallocateRequest for disc_lba: 003A944041 CHS: 00000F8A.04.00C7
RECOV Servo Op=00A5 Resp=0005
RECOV Servo Op=01A5 Resp=0005!
Author:  pepe [ August 20th, 2024, 16:27 ]
you are likely going to kill SA on H0 and some of the disabled surfaces doing this...
