 Post subject: WD Palmer 2.5" failed to unlock : Wrong size of ROM file
PostPosted: October 30th, 2025, 6:06
I have WD Palmer 2.5", HDD is no issue at all working as normal. I ma just need to save the SA < I need some module on it.
But during unlock I failed to proceed.
1. Copy ROM IC using programmer.
2. Upload the file, and unlock, fail :
Creating unlocked ROM...
Family : .......................................: Palmer
Data source of original ROM file : .............: from file
Path of original ROM file: F:\ROM ORIGINAL WD10SPZX WX41AA926JVS\MX25U8032E@SOP8.BIN
Wrong size of ROM file!
Create unlocked ROM : ..........................: Failed
Technology mode key : ..........................: OK
Any body knows what is the problem?
Thank you
 Post subject: Re: WD Palmer 2.5" failed to unlock : Wrong size of ROM file
PostPosted: October 30th, 2025, 17:26
And your file size is how much...?
PostPosted: October 30th, 2025, 19:34
Thank you
bug in v 21112 downgrade to 2193 it will be solved
PostPosted: November 1st, 2025, 3:55
Lukas, file size in attachment. It my capacity issue ?
Alhalal555 , I am using MRT 2193.
PostPosted: November 1st, 2025, 11:28
1025KiB is too big. It should be 1024KiB. This IC has an additional 4Kbit OTP area for serial number and special data.
https://www.macronix.com/Lists/Datasheet/Attachments/8639/MX25U8032E,%201.8V,%208Mb,%20v1.4.pdf
Upload your ROM dump so we can see what is happening.
PostPosted: November 1st, 2025, 12:58
try 2173
