 Post subject: Hitachi
PostPosted: December 16th, 2025, 2:37
any one can help me fix this
Module PESD copy ................................. : OK
MFGP.............................................. : OK
Module SRST copy ................................. : OK
Module FLOG copy ................................. : OK
Module DUMP copy ................................. : Error
Module RESF copy ................................. : Error
Module â copy ................................. : Error
Module ÿÿ¹ copy ............................... : Error
Module PTCH copy ................................. : Error
Module Î[ copy ................................. : Error
Module  copy .................................... : Error
Module PTRT copy ................................. : Error
Module  copy ................................... : Error
Module ÿÿ copy ................................ : Error
Module CHNL copy ................................. : Error
Module ˜& copy .................................. : Error
Module FZ copy .................................. : Error
Module ICES copy ................................. : Error
Module J copy .................................... : Error
Module [ copy .................................. : Error
Module PNID copy ................................. : Error
Module ”€ copy ................................ : Error
Module SSTL copy ................................. : Error
 Post subject: Re: Hitachi
PostPosted: December 16th, 2025, 2:50
Can you upload the ROM and USAG module? To me, it looks like the module directory is corrupt.
PostPosted: December 16th, 2025, 5:24
this is the ROM and the USAG i could not backup it
File comment: do you need these too ?
ROM.rar [78.6 KiB]
Downloaded 201 times
PostPosted: December 17th, 2025, 9:15
is there any updates ?
PostPosted: December 17th, 2025, 15:47
Your ROM doesn't have a directory, at least none that I can find. Also, your dump is twice as large as the actual ROM (the first and second halves of the ROM dump are identical).
ISTM that your USAG module is the problem.
PostPosted: December 17th, 2025, 23:53
I had a look at some resource dumps. I couldn't find USAG, so it appears I was wrong. The firmware must use some other method to find the SA modules.
It looks like the RESF module contains the directory. I would examine that.
Example:
Offset(h) 00       04       08       0C       10
00000000  52455346 43363056 00000000 00000000 52455346  RESFC60V........RESF
00000014  FFFF0000 E27F0200 FFFF0F00 00000100 52414D30  ÿÿ..â...ÿÿ......RAM0
00000028  FFFF0200 E27FA500 00880500 00000100 4F565230  ÿÿ..â.¥..ˆ......OVR0
0000003C  FFFFA700 E27F1200 00D20600 00000100 52455346  ÿÿ§.â....Ò......RESF
00000050  FFFFB900 E27F0200 FFFF0F00 00000100 50544348  ÿÿ¹.â...ÿÿ......PTCH
00000064  FFFFBB00 E27F0300 FFFF0F00 00000100 434E5331  ÿÿ».â...ÿÿ......CNS1
00000078  0000BE00 E27F0100 CE5B0300 C8010100 5257434E  ..¾.â...Î[..È...RWCN
00000370  FFFF0000 E97F7801 FFFF0F00 00000010 454E442E  ÿÿ..é.x.ÿÿ......END.
PostPosted: December 18th, 2025, 0:13
Example:
Offset(h) 00   02   04   06   08   0A   0C   0E   10   12
          Name           Location  Size
00000000  5245 5346 FFFF 0000 E27F 0200 FFFF 0F00 0000 0100  RESFÿÿ..â...ÿÿ......
00000014  5241 4D30 FFFF 0200 E27F A500 0088 0500 0000 0100  RAM0ÿÿ..â.¥..ˆ......
00000028  4F56 5230 FFFF A700 E27F 1200 00D2 0600 0000 0100  OVR0ÿÿ§.â....Ò......
0000003C  5245 5346 FFFF B900 E27F 0200 FFFF 0F00 0000 0100  RESFÿÿ¹.â...ÿÿ......
00000050  5054 4348 FFFF BB00 E27F 0300 FFFF 0F00 0000 0100  PTCHÿÿ».â...ÿÿ......
00000064  434E 5331 0000 BE00 E27F 0100 CE5B 0300 C801 0100  CNS1..¾.â...Î[..È...
00000078  5257 434E 0000 BF00 E27F 0100 CE5D 0300 F800 0100  RWCN..¿.â...Î]..ø...
0000008C  5A4F 4E45 0300 C000 E27F 1100 0038 0300 F61F 0000  ZONE..À.â....8..ö...
000000A0  5054 5254 0000 D100 E27F 0200 E03F 0000 2006 0000  PTRT..Ñ.â...à?.. ...
000000B4  534D 5254 FFFF D300 E27F 0100 FFFF 0F00 0000 0010  SMRTÿÿÓ.â...ÿÿ......
000000C8  5352 5650 0000 D400 E27F 0200 1064 0300 F603 0100  SRVP..Ô.â....d..ö...
000000DC  5352 564D 0300 D600 E27F 0700 002A 0300 000E 0000  SRVM..Ö.â....*......
000000F0  4348 4E4C 0300 DD00 E27F 1500 0000 0300 9826 0000  CHNL..Ý.â.......˜&..
00000104  4944 4E54 0000 F200 E27F 0200 465A 0300 B800 0100  IDNT..ò.â...FZ..¸...
00000118  534E 3030 0000 F300 E27F 0100 5A5A 0300 1400 0000  SN00..ó.â...ZZ......
0000012C  4D49 5343 0300 F400 E27F 0100 245B 0300 1C00 0111  MISC..ô.â...$[......
00000140  4943 4553 0000 F500 E27F 0100 485B 0300 4A00 0111  ICES..õ.â...H[..J...
00000154  4D4C 4241 0000 F600 E27F 0100 145B 0300 0A00 0111  MLBA..ö.â....[......
00000168  514D 434E 0300 F700 E27F 0400 008A 0300 0008 0110  QMCN..÷.â....Š......
0000017C  534D 5254 0300 FB00 E27F 0100 CE5E 0300 D201 0110  SMRT..û.â...Î^..Ò...
00000190  504E 4944 FFFF FC00 E27F 0200 FFFF FF00 0000 0211  PNIDÿÿü.â...ÿÿÿ.....
000001A4  534D 5241 0300 FE00 E27F 0100 9480 0300 6001 0100  SMRA..þ.â...”€..`...
000001B8  4142 4C50 0000 FF00 E27F 0100 546D 0300 6800 0100  ABLP..ÿ.â...Tm..h...
000001CC  4142 4C44 0300 0001 E27F 0100 C46C 0300 9000 0111  ABLD....â...Äl......
000001E0  5353 544C FFFF 0101 E27F 0200 FFFF 0F00 0000 0110  SSTLÿÿ..â...ÿÿ......
000001F4  5345 524C 0400 0301 E27F 0200 00FC 0200 0004 0110  SERL....â....ü......
00000208  5353 5354 0400 0501 E27F 0100 006C 0000 0002 0110  SSST....â....l......
0000021C  534B 504F 0400 0601 E27F 0100 6C6B 0300 9000 0110  SKPO....â...lk......
00000230  4443 4F54 0000 0701 E27F 0100 305A 0300 1600 0110  DCOT....â...0Z......
00000244  5352 4946 0000 0801 E27F 0100 686B 0300 0400 0010  SRIF....â...hk......
00000258  4255 4C4B 0000 0901 E27F 0100 FC6B 0300 B000 0111  BULK....â...ük..°...
0000026C  414C 5454 0300 0A01 E27F 0100 005A 0000 0002 0000  ALTT....â....Z......
00000280  4442 4743 0300 0B01 E27F 0100 0C9F 0300 4E00 0100  DBGC....â....Ÿ..N...
00000294  4F46 4454 FFFF 0C01 E27F 0100 FFFF 0F00 0000 0100  OFDTÿÿ..â...ÿÿ......
000002A8  5244 4D54 FFFF 0000 E47F 5000 0038 0A00 0000 0000  RDMTÿÿ..ä.P..8......
000002BC  5245 4C49 FFFF 5000 E47F 0100 00D8 0A00 0000 0000  RELIÿÿP.ä....Ø......
000002D0  5053 4854 FFFF 5100 E47F 7602 00DA 0A00 0000 0000  PSHTÿÿQ.ä.v..Ú......
000002E4  4F56 5231 FFFF 0000 E57F 4800 FFFF 0F00 0000 0100  OVR1ÿÿ..å.H.ÿÿ......
000002F8  5350 5245 FFFF 4800 E57F 3600 FFFF 0F00 0000 0010  SPREÿÿH.å.6.ÿÿ......
0000030C  5045 5344 FFFF 0000 E67F 8000 FFFF 0F00 0000 0010  PESDÿÿ..æ.€.ÿÿ......
00000320  4D46 4750 FFFF 0010 E67F 0100 FFFF 0F00 0000 0010  MFGPÿÿ..æ...ÿÿ......
00000334  5352 5354 FFFF 0000 E77F 8000 FFFF 0F00 0000 0010  SRSTÿÿ..ç.€.ÿÿ......
00000348  464C 4F47 FFFF 0000 E87F 8000 FFFF 0F00 0000 0010  FLOGÿÿ..è.€.ÿÿ......
0000035C  4455 4D50 FFFF 0000 E97F 7801 FFFF 0F00 0000 0010  DUMPÿÿ..é.x.ÿÿ......
00000370  454E 442E 0000 0000 0000 0000 0000 0000 0000 0000  END.................
PostPosted: December 18th, 2025, 3:53
this is what i get when doing SA test:
Test : SA structure test
Reading NV-RAM.................................... : OK
Module RSVD copy 0................................ : OK
Module RSVD copy 1................................ : OK
Module RSVD copy F................................ : Error
RESF.............................................. : OK
RAM0.............................................. : OK
OVR0.............................................. : OK
PTCH.............................................. : OK
CNS1.............................................. : OK
RWCN.............................................. : OK
ZONE.............................................. : OK
PTRT.............................................. : OK
SMRT.............................................. : OK
SRVP.............................................. : OK
SRVM.............................................. : OK
Module CHNL copy 0................................ : Error
Module CHNL copy 1................................ : Error
Module CHNL copy F................................ : Error
.................................................. : Error
IDNT.............................................. : OK
SN00.............................................. : OK
RwLu.............................................. : Error
MISC.............................................. : OK
Q|Oy.............................................. : Error
ICES.............................................. : OK
K@|............................................. : Error
MLBA.............................................. : OK
KuGr.............................................. : Error
QMCN.............................................. : OK
Module PNID copy 0................................ : OK
Module PNID copy 1................................ : OK
Module PNID copy F................................ : OK
==>>.............................................. : Error
SMRA.............................................. : OK
(................................................. : Error
ABLP.............................................. : OK
oãêá........................................... : Error
ABLD.............................................. : OK
Module SSTL copy 0................................ : OK
Module SSTL copy 1................................ : OK
Module SSTL copy F................................ : OK
Module SERL copy 0................................ : OK
Module SERL copy 1................................ : OK
Module SERL copy F................................ : Error
Module SSST copy 0................................ : OK
Module SSST copy 1................................ : OK
Module SSST copy F................................ : Error
0ÿ0`............................................. : Error
Module DCOT copy 0................................ : Error
DCOT.............................................. : OK
Module SRIF copy 0................................ : Error
SRIF.............................................. : OK
Module BULK copy 0................................ : OK
Module BULK copy 1................................ : Error
Module BULK copy F................................ : OK
ALTT.............................................. : OK
DBGC.............................................. : OK
OFDT.............................................. : OK
RDMT.............................................. : OK
Module RELI copy 0................................ : OK
Module RELI copy 1................................ : OK
Module RELI copy F................................ : OK
Module PSHT copy 0................................ : Error
Module PSHT copy 1................................ : Error
Module PSHT copy F................................ : Error
OVR1.............................................. : OK
Module SPRE copy 0................................ : OK
Module SPRE copy 1................................ : OK
SA struct test................................... : OK
PostPosted: December 18th, 2025, 9:38
without CHNL you are not gonna get data. PSHT would be nice too.
PostPosted: December 18th, 2025, 16:12
Can you upload all your module dumps?
