 Post subject: Partition 03 - NTFS - 73.24 GB - data
PostPosted: February 21st, 2022, 15:38
Hello
how to make MRT save files without (Partition 03 - NTFS - 73.24 GB - data) like PC3000 ?
because it makes a lot of files under (long files names)
 Post subject: Re: Partition 03 - NTFS - 73.24 GB - data
PostPosted: February 22nd, 2022, 2:28
That's a bug that hasn't been resolved in years, unfortunately....
www.datasave.ro
PostPosted: February 27th, 2022, 17:09
:row:
like now saving customer files, all of it in the Long path files folder.
the 255 characters limit are wasted with
G:\FILE IMAGE - Mrt Data Explorer.FileImg - 1863.02 GB\GPT partition - 1863.02 GB\Partition 04 - NTFS - 1836.76 GB - Windows8_OS\Root\Users\lenovo
PostPosted: February 27th, 2022, 17:48
Could this be the solution to the "long path" problem?
https://www.howtogeek.com/266621/how-to-make-windows-10-accept-file-paths-over-260-characters/
PostPosted: February 27th, 2022, 19:55
Use UFS Explorer to save the files out instead. You can use the map file so the good and damaged split to separate folders.
PostPosted: March 1st, 2022, 0:05
Mount the Task and use recovery softwares like r-studio, Dmde, Active File Recovery etc
PostPosted: April 7th, 2026, 10:47
LongPathTool resolves issues caused by deeply nested folder structures.
