| WD ROM Help http://forum.hddguru.com/viewtopic.php?f=28&t=46368 |
Page 1 of 1 |
| Author: | Core.iStores [ October 25th, 2026, 4:08 ] | |||
| Post subject: | WD ROM Help | |||
Could someone help me repair this ROM please ?
| Author: | Mikippp [ October 25th, 2026, 4:50 ] |
| Post subject: | Re: WD ROM Help |
Hi, Why do you think there is an issue with the ROM? Mikippp |
| Author: | MindMergepk [ October 25th, 2026, 5:35 ] |
a donor ROM can also be used if you know certain information about the original ROM. but again as Mikippp said why you think there is a problem with the ROM.. what is behavior of drive with original ROM ? |
| Author: | Core.iStores [ October 25th, 2026, 6:04 ] |
Mikippp wrote: Hi, Why do you think there is an issue with the ROM? Mikippp After unlock it and reflash it to the chip it give no sign of life |
| Author: | Core.iStores [ October 25th, 2026, 6:08 ] |
MindMergepk wrote: a donor ROM can also be used if you know certain information about the original ROM. but again as Mikippp said why you think there is a problem with the ROM.. what is behavior of drive with original ROM ? When i turn on the hdd it only gives the model number |
| Author: | Core.iStores [ October 25th, 2026, 8:22 ] | ||
| Post subject: | Re: WD ROM Help | ||
now i have this issue
| Author: | fzabkar [ October 25th, 2026, 8:40 ] |
It appears that the drive is identifying itself with the information in the ROM: Code: Analysing active 0x0D module ... Firmware Version = 05.01A05 World Wide Name = 50014EE213686C7E Model Number = WDC WD10SPZX-24Z10 Serial Number = That suggests that it cannot read, or make sense of, module 0x02. Are you able to upload 0x02? |
| Author: | Core.iStores [ October 25th, 2026, 9:04 ] | ||
fzabkar wrote: It appears that the drive is identifying itself with the information in the ROM: Code: Analysing active 0x0D module ... Firmware Version = 05.01A05 World Wide Name = 50014EE213686C7E Model Number = WDC WD10SPZX-24Z10 Serial Number = That suggests that it cannot read, or make sense of, module 0x02. Are you able to upload 0x02? this one ?
| Author: | fzabkar [ October 25th, 2026, 9:11 ] |
That looks OK. The model number is longer -- WD10SPZX-24Z10T1 (SA module 02) versus WD10SPZX-24Z10 (ROM module 0D). |
| Author: | Core.iStores [ October 25th, 2026, 9:36 ] |
fzabkar wrote: That looks OK. The model number is longer -- WD10SPZX-24Z10T1 (SA module 02) versus WD10SPZX-24Z10 (ROM module 0D). yes what should i do now ? |
| Author: | fzabkar [ October 25th, 2026, 10:10 ] |
I have no idea. Yours peers would know better than me. |
