 Post subject: What connector is this?
PostPosted: August 22nd, 2009, 23:00
Toshiba A135 laptop, 2007
Hitachi Travelstar 2.5 PATA HDD HTS541680J9SA00
I need to get the data off this HDD but I'm puzzled by the connector.
It isn't a normal IDE connector with pins, it's more like a male edge connector.
What kind of adapter do I need to hook this up to my 3.5 IDE-to-USB adapter? What's it called? What am I looking for? (And where can I get it?) :?
 Post subject: Re: What connector is this?
PostPosted: August 22nd, 2009, 23:47
Er, it's SATA, not PATA.
PostPosted: August 23rd, 2009, 0:49
Sata to IDE adapter?
PostPosted: August 24th, 2009, 13:15
Ooooooh. It's just an ordinary SERIAL connector? Thanks. :mrgreen:
PostPosted: December 4th, 2009, 5:39
This is known as 2.5" SATA / S-ATA (Serial ATA) laptop hard drive. It is the type of hard drive that is used by modern day laptops and succeeded IDE(also known as PATA, DMA, UDMA,ATA, P-ATA, Parallel-ATA)which has connector pins. You could use a 2.5" SATA external caddy enclosure which has a sata connection-one end will connect to the hard drive and the other will connect to your laptop/pc via USB. I hope that helps
Laptopdrivestore.com - New and Refurbished Laptop Hard Drives
PostPosted: May 15th, 2010, 9:51
this is a SATA HD
try to get/buy the SATA to USB Adapter
PostPosted: May 15th, 2010, 11:38
This thread is 10 months old...
