 Post subject: Dell Specialists ?
PostPosted: May 19th, 2011, 14:15
I ask for the pin assignment of laptop battery for Dell Vostro 3750 or compatibles.
There are a lot of compatible Dell laptops using same battery - like:
Dell Inspiron 13R (N3010), 14R (N4010), 14R (N4110), 15 (M5020), 15 (M5030),
15 (N5020), 15 (N5030), 15R (N5010), 15R (N5110), 17R (N7010), 17R (N7110)
and Vostro 3450, 3450n, 3550, 3550n, 3750n
Battery part numbers:
0383CW, 04YRJH, 07XFJJ, 0J1KND, 0J4XDH, 0W7H3N, 312-0233, 383CW, 3UR18650A-2-DLL-39,
4YRJH, 7XFJJ, J1KND, J4XDH, P07F, P07F001, P07F002, P07F003, P08E, P08E001, P10S, P10S001,
P11G, P11G001, P13E, P13E001, P14E, P14E001, P16F, P16F001, P17F, P17F001, P19G, P19G001,
P20G, P20G001, UM7, UM8, UM9, W7H3N
Thank you in advance
 Post subject: Re: Dell Specialists ?
PostPosted: May 19th, 2011, 16:36
Umm... Googled and found this:
http://www.laptop-junction.com/toast/co ... nal-timing
It should help
PostPosted: May 19th, 2011, 16:59
Thank you - but this is no compatible modell - it has to
be the one stated above. (Dell Vostro 3750 or compatible)
Each battery has usually: +, -, data, controll = 4 pins
Each laptop manufacturer has his own pin assignment,
but this can even be different for each laptop model.
We sell an external battery charger for laptop batteries.
If I would have a battery on stock, I could easily find
the pins - and now I have a request for a bigger quantity
and dont know the pin assignment for above Dell model.
Manufacturer of charger doesnt know, Dell doesnt know ....
Looks like I have to buy one battery to test it ... or
one of you can help.
PostPosted: May 23rd, 2011, 14:06
Ok, case is solved
the customer has organised Dell to send me a battery that I can
test our external laptop battery charger with this specific battery.
