 Post subject: recommended drive for online high density storage?
PostPosted: October 10th, 2011, 21:38
Hello, Thank you for reading this
I need to keep online 4 TB of data 24/7/365 year, I have a w2008 server with 4 x 1TB WD10EARS but in the last 10 months, I had two failures, both hanged the server badly and I have to remove the failed drive to be able to use it again.
The two failures where from different drives, and both where temporary, because after doing a full surface read/write (copying data from the disk with a file manager, erase it, and write the data back) the disk cleared smart (197: current pending sector & 200 multi-zone error rate) and started working normally again.
so I came to the conclusion that this drives are not reliable enough for 24/7 usage (you are probably leafing your ass off with that statement as it probably not anything new for you hehe)
so... what can I use (without going to savvio SAS incredibly expensive drives) to keep my data online reliably?
I was thinking on using 2x 2GB WD RE4-GP drives, but I really will like to know your opinions, since you are the hands on guys that really used hundreds of different disks, before go spending money on enterprise class drives.
I will really love to hear your comments, thank you!.
EDIT: I read here that drives with 4 platters are more prone to failure and WD RE4-GP 2GB has 4 platters 8 heads :( any comment on this?
Indkt.
 Post subject: Re: recommended drive for online high density storage?
PostPosted: October 11th, 2011, 4:07
My personal experience says that WD Re4 (and RE3 too) are a very good choice for stability, speed and reliability.
These are the ones i use on my personal machines and where i keep my personal and business files too (4x WD1003FBYX + 2xWD2004FYYS)
I'd love to hear others' opinions too, though.
PostPosted: October 12th, 2011, 21:22
Hi!, Thank you for answer!!, so you are using WD RE4 not WD RE4-GP right?, they are almost at the same price so it would be ok.
thank you for your input, anyone else?
