 Post subject: Smart Question about JPEG
PostPosted: February 20th, 2012, 12:49
Well, sometimes i come up with few tasks which might be Impossible
anyway
here is the Task Question:
How do you disable the JPEG thumbs view for specific image?
in another word:
I have a JPEG image, and i wanted this image to be viewed on any PC when you OPEN it
but when you use THUMBNAILS i don`t wanted it to be VIEWED.
which looks like a damaged image, but once double click it works and shows the image
Any Clues??? :idea: :idea:
 Post subject: Re: Smart Question about JPEG
PostPosted: February 20th, 2012, 14:48
So, you have a jpg with working image but damaged embedded thumbnail?
You should be able to use exiftool to remove the exif thumbnail; then if a thumbnail is going to be displayed (by windows or whatever) it will have to be generated from the real image instead of using the damaged embedded thumbnail
PostPosted: February 20th, 2012, 15:23
i did it, but didn`t work (tried that)
and still working on it through the command like & gui as well
:wink:
i was wondering if there is such util. to remove the thumbnail image from the jpg
