 Post subject: Firmware edit is it possible?
PostPosted: March 7th, 2012, 21:41
I have seagate ST3750640NS firmware 3.AEK, I need to change following "smart" values in the firmware:
Execute Off-line Immediate,Supported to Not supported
Off-line Read Scanning,Supported to Not supported
Short Self-test,Supported to Not supported
Extended Self-test,Supported to Not supported
Selective Self-Test,Supported to Not supported
Save Data Before/After Power Saving Mode,Supported to Not supported
Enable/Disable Attribute Autosave,Supported to Not supported
Error Logging Capability,Supported to Not supported
Security Frozen,No to Yes
is this possible? Maybe low level command program that can accomplish this?
 Post subject: Re: Firmware edit is it possible?
PostPosted: March 9th, 2012, 6:22
Certain feature sets can be disabled/enabled using a Device Configuration Overlay (DCO).
See section 7.10.3 of the following document.
Working Draft AT Attachment 8 - ATA/ATAPI Command Set (ATA8-ACS):
http://www.t13.org/documents/UploadedDo ... A8-ACS.pdf
