 Post subject: how to remove wright protection from a hdd
PostPosted: September 6th, 2012, 12:28
need help removing wright protection from a hdd
thanx
 Post subject: Re: how to remove wright protection from a hdd
PostPosted: September 6th, 2012, 12:44
(a) For the benefit of other readers, this is a duplication of part of the ongoing thread in the recovery forum:
wd20ears-locked-pvr-t23924.html
(b) With respect, although it may seem an obvious thing to you, you're asking the wrong question IMHO. You don't remove write protection - you have to diagnose and then fix whatever underlying problem is causing that to be reported, since that error is a symptom of something else.
I've asked a relevant question in the above thread which you haven't yet answered, to help to eliminate a common cause of that error. I suggest that you continue with that previous thread which you started, rather than "going off at a tangent" in this new thread, OK?
PostPosted: September 6th, 2012, 13:14
sorry for posting here il keep going with the other post
it would seem the lg bluray player has set a password
MHDD reports the drive is locked to a ata password
