 Post subject: Silly Question about Flash memories
PostPosted: August 21st, 2012, 9:47
Dear Guys,
i got many flash memories from my DR and also bulk dead flashes i bought for testing my SC long time back
for now, i have more than 200+ memory chips which are useless for me after delivering my data to my clients
the question is the following:
is there any way to put them together on some sort of SSD for example?
i bought some BLANK flashes some time ago for soldering flash memory to it, but those are most with SINGLE memory chip on it
any change of having for example 8 or more chips so i can use them again as an SSD or anything??
i feel bad really when i see those in my archived drawers here.
hope someone can give me any idea for them? DIY is fine also with me, since i enjoy it more
thank you
:wink:
 Post subject: Re: Silly Question about Flash memories
PostPosted: September 18th, 2012, 19:31
have you gotten anywhere with this? I managed to switch a single chip from a working flash drive as a replacement for a failed OCZ unit to repair it, just as a hobby. It was the same manufacturer chip though..
If you could modify the firmware, you could likely get a half-populated 16 chip board and try and fill in the other 8...
PostPosted: September 19th, 2012, 6:23
the question is who sells those BLANK SSD pcb`s?
so far no one, but i tried to buy new SSD and worked with the help of SC TS.
if you know any who sells let me know
10x
